Rear view mirrior change..
Old Sep 2, 2008 | 11:10 AM
TORCHD 02 TA's Avatar
Originally Posted by Snuffles
eBay.
The wiring information, part number, etc. is in the link in post #14 of this thread.
Thanks i will have to look into this...
EDIT: The model you have, GNTX-177, is that out of the Sierra?
Also where did you mount the temp sensor?
Old Sep 2, 2008 | 11:39 AM
Snuffles's Avatar
Yes. It was out of a Sierra.
(Keep in mind you lose the maplights with this mirror.)
I mounted my sensor behind the front bumper.
Many people mount it lower to the ground, around the foglight areas.
That's probably the best place for it. I plan on moving mine because I feel the heat from the motor throws it off.
I apologize for the crappy pic.
It was taken a year ago and it's the only picture I have that shows where the sensor is mounted.
Old Sep 2, 2008 | 12:45 PM
sucks i cannot find any mirrors right now
Old Sep 2, 2008 | 01:09 PM
will the rear view mirror out of a Trail Blazer work?
It has temp, compass and wiring harness for gentex... I jsut do not want all the Onstar buttons..
EDIT: I found a mirror out of an 04 Silverado.
Auto Dim : Yes
Compass : Yes
Gentex or Donnelly : Gentex
Gentex/Donnelly Part # : 261
Homelink : No
OnStar : No
Sensor : Yes
Temperature : Yes
Wiring : Pigtail (Approx 4-6")
Old Sep 2, 2008 | 01:33 PM
Originally Posted by JJsQwuik
has anyone upgraded thier rear view mirrios like the ones from GMMG, with the compass, temp and lens dimmer??? will the ones from tahoe and silverados work with an upgrade to the outside temp sensor....
What GMMG mirrors are you referring to?
Got any pics?
Old Sep 2, 2008 | 03:05 PM
Snuffles's Avatar
Auto Dim : Yes
Compass : Yes
Homelink : No
OnStar : No
Sensor : Yes
Temperature : Yes
That sounds like it will work.
It has the sensor and some of the pigtail, which is a good thing.
The only thing I'd check for is to make sure it uses the same mirror button as ours. (The metal piece that is glued to window.)
Even if it doesn't you can install one that will work with the mirror.
There is a model that DOES have the maplights along with the compass and temperature readings.
I just don't remember which model it was.
Old Sep 2, 2008 | 03:13 PM
my question is how do you go about wiring the pigtail and other stuff?
Old Sep 2, 2008 | 04:41 PM
Snuffles's Avatar
The answer to that is specific to the model mirror (or the pigtail).
You should have 5 wires coming out of the back of the particular mirror you posted above.
The wires are most likely as follows:
- 12v ignition
- ground
- reverse dim inhibit
- temperature sensor wire #1
- temperature sensor wire #2
You have to find is a 12v ignition wire and tap into that.
The rest is cake. (Grounds, temp. sensor wires, etc.)
If you want to get fancy you can even hook up the reverse dim inhibit wire.
... It disables the auto-dimming feature while you're in reverse.
The hardest part is determining which wires do what coming out of the back of the pigtail.
Then all it is is running some wires and then splicing.
Old Sep 2, 2008 | 05:06 PM
GreenBlood's Avatar
hmmm...guess i'll stick with the stocker...
Old Sep 2, 2008 | 05:14 PM
- 12v ignition
- ground
Come to Chicago and install this thing for me
Old Sep 2, 2008 | 06:53 PM
LS1BLKSS's Avatar
Banned Village Idiot
Originally Posted by Lrry93
thast too much for that!!!!!
Old Sep 2, 2008 | 07:01 PM
  #32
JJsQwuik's Avatar
if you go to GMMGinc.net all of their cars havethat rear view mirror upgrade.
Old Sep 2, 2008 | 09:21 PM
  #33
yes you're right i saw that..
Old May 23, 2010 | 11:58 PM
  #34
JJsQwuik's Avatar
Sorry guys but i gotta bring this thread from the dead, Im about to do it to my car....
Old May 24, 2010 | 10:18 AM
  #35
Danny2tek's Avatar
Got mine New from ebay... led map lights, self dimmer, compass, temp.
Attached Thumbnails Rear view mirrior change..-img00073-20100524-1107.jpg   Rear view mirrior change..-img00072-20100524-1106.jpg
Old May 24, 2010 | 11:28 AM
  #36
marksboy7's Avatar
What all did you have to do to set that up? Also what is the mirror out of?
Old May 24, 2010 | 11:54 AM
  #37
mikehaase1norse's Avatar
Originally Posted by Havok2
250 to tell me im driving north/south/east/west?
nah ill pass
agree, 30-50 if it had map lights is fine but 250?! id rather spend 250 on hookers and blow...
Old May 24, 2010 | 12:17 PM
  #38
Danny2tek's Avatar
IIRC I had to tap into a switched 12+, used the existing power for the map lights and just ran the temp sensor. As for what the mirror itself is made of? I don't know glass?
its made by GenTex
Old May 24, 2010 | 12:22 PM
  #39
Trans Am Jam's Avatar
haha that's ridiculous.
Old May 24, 2010 | 09:06 PM
  #40
Nice Danny.. What mirror is that one? Was it hard to wire it up?
Also where did you put the temp sensor at?
