where to buy switchback led and what is needed for install
Old Aug 31, 2008 | 01:30 PM
1sicLS1's Avatar
Default where to buy switchback led and what is needed for install
I need to know what is needed done for a switchback led install. I have tried to find the leds on the net with no luck are they called something else besides switchback. I checked [non-sponsor link removed] like some said and cant seem to find them. Also if there is a write up that would be very helpful. I didnt know if this is just plug and play or if there is any modifiying needed to be done. Any help is appreciated
Old Aug 31, 2008 | 01:46 PM
Brian2006's Avatar
No modifying. Plug and play. You also need an EL12 flasher
Old Aug 31, 2008 | 03:30 PM
McCauleyWB's Avatar
Go to the site you mentioned and follow up the URL with "/switchback.html"
I believe it is the 20 led #3157 and it seems most people turn to AutoZone for the flasher. Please, someone correct me if I am mistaken.
Old Aug 31, 2008 | 03:43 PM
Brian2006's Avatar
You are correct. However, you can only use the 20 LED towers in camaros. Anything bigger won't fit.
Old Aug 31, 2008 | 10:56 PM
ElkyRacer's Avatar
What would be a good match for the other small light in the housing?
Old Aug 31, 2008 | 11:23 PM
TheSilverOne's Avatar
not a lot of good choices for 194's
Old Sep 1, 2008 | 01:52 AM
McCauleyWB's Avatar
The same site that carries the switchbacks also carry 5 led 194s (site + "/194.htm"). I have only begun reading about lighting changes, so I can not positively say these would work or not. If so, I will be purchasing these as well.
Old Sep 1, 2008 | 02:13 AM
98 WS6's Avatar
So what should be used for a T/A?
Old Nov 4, 2008 | 12:53 PM
vintageagain's Avatar
Does anyone have a problem with the Radio after installing the switchbacks? I've noticed that my radio reception goes out when the blinker is on and when my DRLs/Headlights are on. I tried a regular bulb 3157 and didn't have the same problem. Anyone know of any fixes?
Old Jan 5, 2009 | 12:53 PM
Magnet's Avatar
can someone pm me the nonsponsor please..
Old Jan 5, 2009 | 08:59 PM
slippinsideways's Avatar
same please.
Old Jan 6, 2009 | 12:38 AM
greendrazil's Avatar
I need that pm as well.
Old Jan 7, 2009 | 11:06 AM
Twigs's Avatar
Same, could someone PM me the link also
Old Jun 1, 2009 | 06:38 PM
ls1ssws6's Avatar
back from the dead, could someone pm me the non sponsor link as well
Old Nov 12, 2009 | 05:08 PM
Turb0Z28's Avatar
pm me the link also
