VFN Sunoco hood adjustment
Thinking about my problem (high front) I'm going to drill a little more into the bracket holes closest to the front of the car. If that doesn't work I'll strongly consider hood pins.
Also, has anyone heard of putting cold water on a hot fiberglass hood to help shape it? Someone told me this and I'm not sure if it is worth trying?
Let's let vfn in here to possibly help out,. You could always call them too.
... Hope that works.
Now... try the same sequence that I posted earlier, but when you're adjusting the latch down, drop the pass. side bolt (13mm) about 1/4 inch lower than the driver side. I know that they're only a few inches apart, but you'd be surprised at the difference it can make when that slight angle is multiplied over the distance from the latch to the high corner. You'll wanna be sure to loosen the u-bolt on the hood a bit before you close the hood though... reason being that when you're dropping the left side of the latch lower, you can imagine that the entire latch is going to sit at a bit of an angle. Instead of the opening at the top of the latch facing straight up, it will now be angled a bit towards the left. When you close the hood, the u-bolt will need to feed in from about 1/4 inch further to the left than it did originally. Basically what is going to happen is the latch will pull the hood down on the passenger side a bit more than it will the driver side. Give that a shot and it should level everything out. You'll probably feel some tension when closing the hood now, but don't worry. After a few heat cycles (running the car, letting it cool, running, and so-on) the hood will close with less force. Good luck with it and let me know if you need anymore ideas.
It drives me nuts!
