Is this a fair price for tints?
I just got off the phone with a local audio shop and they told me $185 for all the door windows and rear window. I only have tint on my rear window which is all blue, and he said $40 per window for tint removal.
Is this good? Also do you think the tints are really worth it? I have a full bolt on car and I don't think I could use the money for anything else..
Thanks guys
Unfortunately I just got a ticket for side window tint, and now I have to remove it
That's a real good deal, but is it the lowest grade tint? What % are you looking at getting?
If youre getting 5% make sure it's good tint because if it isnt the tint will turn blue.
I will probably re-do the tint, but it sucks that I have to remove what is on there right now because its a nice tint job...
I don't know about the tint grade, I only called for a price. I'm still deciding whether or not I should do it.
But could I just rip off the old tint on the hatch without hurting the defroster lines?
For the tint removal, go to any local auto parts store (advanced, autozone, ect...) and get some tint remover (basically it's just a spray bottle with ammonia in it). Get a black lawn trash bag and tape it over the outside of the glass on a nice sunny day, and spray the inside where the tint is, and let it bake in the sun for a bit. (remember, the sun should be hitting the trash bag that's on top of the window). Make sure to leave the doors open to air out, because you dont want those ammonia fumes in the car while you are letting the ammonia do it's job. Then after about 30 minutes, take off the trash bag and take a razor blade and work one of the corners of the window till you can get a fingers grip on it, then just pull gently and it should all come off in one nice sheet. Be careful with the rear hatch if you use the razor blade, because YES you can cut through one of the defroster lines, and that will cause that line to not work.
If you try it without the ammonia like i did for one window, it will take all day and will be VERY messy.
Another important thing to make sure of is that if you plan to get the windows retinted, and you remove the original tint yourself MAKE SURE that you get ALL of the glue/residue from the original tint job off of your window. I cleaned mine with hot water and dishwasher detergent.
As for the darkness....i currently have 5% on the rear hatch and 35% on the sides. I think it's the perfect percentage myself, even after having 5%. It's dark enough where you can only see the outline and MAYBE facial features if the light shines in just right. But for the most part, it looks very sweet on the car.
But, I think that I am going to pull the old **** off myself then take it in to get it tinted.
Also, maybe try doing it in the sun, or with a hair dryer, it might make it come off easier, but I don't know from experience YET (next couple of days I will know all about it, lol).
