checked installuniversity and doesnt have this install.
Old Jan 2, 2002 | 02:25 PM
R U A LS1's Avatar
Default checked installuniversity and doesnt have this install.
If i wanted to go out later today and but a FP and air/fuel gauge, would i be able to do this myself or would a shop have to. I'm moderately experienced with installing 3 or 4 things but nothing serious.
Old Jan 2, 2002 | 02:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: checked installuniversity and doesnt have this install.
You could do it yourself if you don't mind running wires, and soldering them.
I have the Autometer AF and fuel pressure gauges, Phantom series.
Old Jan 2, 2002 | 02:36 PM
R U A LS1's Avatar
hey PRJ quick respond and convienent. thanks. Can you splice the wires if i dont have a soldering iron. I just dont know where to put anything. Obviously i can get the power and ground from the same things i attached my shift light too, but does the wireing for the 3rd wire go into the PCM like the shift light does to pin 11 (the white wire i think it is.) Bos took his to a shop, as do others, thats why i ask.
Old Jan 2, 2002 | 02:40 PM
LS1Tech Co-Founder
The fuel pressure gauge runs off of an sender that you put on your fuel rail. You need an adaptor fitting for the fuel rail. You also need to remove the Schrader valve when you do this.
The AF gauge, well, my buddy used a wire right off the pcm, I don't recall which wire. I access the driver's side front O2.
Old Jan 2, 2002 | 02:50 PM
BIGBOS's Avatar
The adapter fitting for the fuel rail is 35 bucks
