Vacuum Modulation in 4L60
Old Sep 13, 2003 | 11:41 AM
BLK02WS6's Avatar
Default Re: Vacuum Modulation in 4L60
Dutch,
I would give Pro-built a call if you are interested in this. I just talked to Dana there and he knows his stuff. He even told me he would be happy to work with my local builder to get me straight with exactly what I want - that is great service.
My plan is to go to my local builder and talk to him about building what I want using the parts from Pro-built. If Pro-built were local to me, or if he had a core, I would just have him build it, but they are all the way across the country and they don't have any cores.
Hope this helps you out too!! Thanks for the post!
Old Sep 13, 2003 | 02:53 PM
Dutch SS's Avatar
Hey BLK02WS6, who are you using for building your tranny? I am in MD too, so let me know who you plan to use and contact info for them also please. If you dont want to post it, please PM me with the info...... Thanx
Old Sep 13, 2003 | 03:04 PM
CRAZYCUBAN29's Avatar
Trans Go makes the kit its called MOD-60 I think. They also make one for the 4L80E called MOD-80. The kits been around for a while now. Maybe since 1993 I think.
Old Sep 13, 2003 | 04:34 PM
Z-Rated's Avatar
can you still play with the shift points electronicly??
Old Sep 13, 2003 | 04:35 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Of course. The modulator only removes PCM input for line pressure, NOT shift points.
Old Sep 13, 2003 | 09:15 PM
BLK02WS6's Avatar
Sent you a PM.
Old Oct 6, 2003 | 10:29 AM
Dutch SS's Avatar
well, I did the vacum conversion......first day was great, you can really tell the difference when the car downshifts......
second day......BOOM!!!!! same issues i was having before with internal breakage
I think it is time for me to make a switch.....6 4l60's this year is getting to be too much.....time for either a 4l80 or t350/400 and GV OD unit.....
I was so hoping the vaccum would help my issues.....
Old Oct 7, 2003 | 03:40 PM
BLK02WS6's Avatar
Dutch, where you gettin your trannies built? I think I wanna stay away from there. As you probably know, the place I PM'd you about is no longer. Don't know where I'm gonna go now. I'm hopin it will hang in through the off season and maybe some other options will come up.
Old Oct 8, 2003 | 07:11 PM
blkmgc1's Avatar
thanks for the website i ordered the stuff for a full manual vacum 4l60e kinda cool stuff.no more electronics sweet.thanks for the info.
Old Jun 20, 2004 | 09:27 PM
Jammer's Avatar
any update/...any other experiences from anyone w/ vac modulation conversions?
Old Jun 22, 2004 | 11:27 AM
Jeff406cid's Avatar
I have found that the vacuum source, and amount have to be right.
It has to be manifold vacuum, and if you have a big cam and low vacuum I don't believe it will work correctly(remember the purpose of manual valve bodies?).
TransGo does make the kit and it installs easily, but you do need a 1/8-NPT tap, and a "R" drill bit to make it work.
Old Jun 25, 2004 | 11:13 AM
  #32
etperformance's Avatar
I used pro-built fo all my 4L60e parts, including vacuum mod. No problems yet. If you buy from Dana, and install the kit like he says, it seems to work pretty good. He knows his stuff.
Old Nov 25, 2004 | 07:21 PM
  #33
trimmen's Avatar
i have a 4l60e in a 01 4x4 5.3.i bought the trans go shift kit ,vett servo,vaccum mod.got it from Dana at pro built.haven't installed it yet but the instructions look simple.you have to tap the pan and tie into the power brake line for the vaccum.Dana is very good at what he does and is very helpful.he will mod the instructions of the kit to suit what you want.he specializes in the 4l60e and 700 tranny.i highly recommend him.good luck fellas.
Old Nov 26, 2004 | 11:21 AM
  #34
Damage Inc.'s Avatar
Sweet Cheeks
Great info here guys.
Old Nov 26, 2004 | 04:38 PM
  #35
Hotrodhawk's Avatar
Ramchargers has the Vac Mod, the part number is 31946-mod and it sells for $109.99
