th350 and th400 stall converters
does anyone know if the th350 and th400 stall converters are interchangable? for example can i take a converter from a th400 and use it on my th350?
As far as the transmissions input shaft, stator and pump gears they are identical inside the converter. There are some differences as far as the mounting pads but most flex plates will work regardless. Vince
