4L60E Hard Line Question
Old Oct 13, 2008 | 08:50 AM
2JZFC's Avatar
Default 4L60E Hard Line Question
Using an LM4/4L60E combo in a swap and bypassing the radiator cooler to a B&M Supecooler. My plan is to use the hard line out of the tranny, cut them about under the starter, use compression/-6AN adaptors, then -6AN Parker Push-lok to the cooler and back. I screwed the hard line fittings into the case, tightened them, pushed the black plastic rings(?) on and even with the fittings tight, the hard lines pretty much flop around.
I have visions of geysers coming out the side of the tranny on startup Have not gotten used to these new types of fittings, but is that normal? I was told by a GM tech that those fittings require no thread sealant, tape or o-ring which tells me it is not pipe thread. While doing searching, I ran across a thread that said it was. MOF, even the threads in a TH400 case is not NPT. It is some other weird xPT but everyone uses NPT. Might be why there are so many reports of cracked cases.
TIA
Old Oct 15, 2008 | 01:49 PM
forcd ind's Avatar
i sort of answered this in another thread-i think the fittings in the trans are 1/4-18 npsm pipe, straight thread-their diff than tapered pipe thread
ATI Performance has the fittings, #6 an to 1/4-18 straight, #925137
i have used them in turbo 400's, it looks like my 4l80e has the same threads
except the rear fitting has a tube on it, i might be able to modify and add a tube to the ATI fitting
Old Oct 15, 2008 | 03:03 PM
allthrotle's Avatar
Are those ati fittings for a 4l60e or a th400?
Old Oct 15, 2008 | 06:21 PM
forcd ind's Avatar
they will fit if your thread is 1/4-18 STRAIGHT thread, which most are-the 4l80e takes a fitting with a tube on it, which is what im gonna try and make out of one
i ck'ed my 4l80e today, seems to be 1/4-18 thread, so i assume the 4l60 is also-
ATI is right up the street from me, so im gonna go grab a couple
Old Oct 15, 2008 | 06:24 PM
allthrotle's Avatar
cool.
