Baddest verter for 3.23s?
i never tried a idle flash which is what works best on this verter. Leaving at around 1800 with a slight roll and punch throttle to save the rear she pulled a 1.55 cam only. Im sure with more runs she would saw some 1.51-2's maybe. I made 4 passes oneday.. 3 had the same 1800 roll launch and they were 1.55, 1.56, and 1.56. Tried to hit the tires WOT from 1800 and i only saw a 1.66 spinnin
with heads and if my rear holds Im 100% certain she could pull a 1.4!! IFFFF the rear lets her
if you wanna try something different, go for the 4200 stalls out there... yank or TCS
there shouldnt be a big difference in the daily driving feelin since you are use to a stall. If anything you would like the looseness more
