Transmission Coolers with Fans
Old Oct 15, 2008 | 02:35 PM
wajouba's Avatar
Default Transmission Coolers with Fans
Do all transmission coolers come with a Temp sensor to stop the fan when tempretures are right? or are some of them manual?!
and which ones do you prefer, the Plate type with Fan or Fin type with fan?
or do you prefer without a fan all together...?!
Thanks
Old Oct 15, 2008 | 04:05 PM
BadBandit69's Avatar
i've got a cooler with a fan and it has a sensor to turn it on automatically but im sure it doesn't turn on till its already 200+. So i wired mine up manually
Old Oct 15, 2008 | 07:43 PM
tim99ws6's Avatar
I have mine wired up to turn on as soon as the key is on. Then I have a fuse for it that is easily accessible. Basically, I pull the fuse until the trans is up to operating temp, then let the fan run all the time.
FWIW-->I have my trans cooler mounted under the rear bumper
Old Oct 15, 2008 | 08:06 PM
MUSTANGBRKR02's Avatar
pics or you are a liar
Old Oct 15, 2008 | 11:00 PM
AutomagicLS1's Avatar
I know someone that did this as well mounted theirs under the rear bumper
Old Oct 16, 2008 | 05:15 AM
tim99ws6's Avatar
I'll get you some pics. I actually really like it there! Clears up alot of room in the front of the car. I'd recommend it to anyone, as it doesn't make the car any less streetable. If i were to DD the car, I'd just install a manual switch to turn on and off the fans. It's just simpler for me to use the fuse....ok, actually i'm just lazy, hahaha
