new tranny break in period
I recommend you (1) Make sure fluid is on the full mark. (2) Manually upshift it for the ten miles. No manually downshifting it till you come to a stop. This will get all of the air out of the servos, accumulators, shift valves, torque converter, cooler, etc. (3) Agian check fluid level, as it will go down some. (4) Next ten miles drive it normally, no more than half throttle. (5) Check fluid level. (6) Now you can start with half to three quarter throttle shifts, and if everything feels fine, start driving the way you want. Dana
