Help tcc unlock
Old Oct 27, 2008 | 09:29 PM
polarischevy05's Avatar
Exclamation Help tcc unlock
randomly driving down the road the converter will unlock with no ses light if i clear the codes it locks back up if i let it go long enough to turn the ses light on it comes up random cylinder mis fire p0300 would it unlock the converter to reduce load on motor to fix the mis fire or do i have another problem.
Old Oct 27, 2008 | 09:53 PM
performabuilt's Avatar
LS1Tech Sponsor
The random misfire is the problem and yes it will unlock the converter when its detected and if continues long enough may turn on the engine light and set a code.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 27, 2008 | 10:40 PM
ok thats what i thought i was just hoping i didn't have trans problems tomorrow i will pull the coil packs and valve covers and check for bent push rods or broken springs the trow a set of coil packs on from a 5.3 i have
