6 bolt tailhousing 4L60e converter ?'s
I bought a 4L60e that was supposedly out of a '95 truck, but has a 6 bolt tailhousing on it.
I had ordered a torque converter from PTC for a '95 4L60e.
Am I screwed?
Thanks,
Brad
Am I screwed?
Thanks,
Brad
If it has a 6 bolt tail housing, it is a two piece case (aka removeable bellhousing)
LS1's only used the two piece case, LS1's have a different input shaft, and other things making the converter different.
If it's a '95 trans, it should have the same input, pump style as the '85 1/2 and up 4L60 and 4L60E. The only differences would be the clutch.
But to answer your question, it sounds like you got the right converter, as long as you told them it was for a '95 4L60E.
