vig 3200 and spray
Old Nov 5, 2008 | 08:25 PM
eric01ss's Avatar
Default vig 3200 and spray
hey guys what are yall footbraking them to?
also how well does it hit at the track and what times are ya'll cutting?
Old Nov 5, 2008 | 08:27 PM
silverz28camaro's Avatar
1.59 60' with my 3600 vig and 3.73 with 245 nittos leaving at idle full bolt on ls6 heads and 224 cam.
Oh 11.56 @117
Old Nov 5, 2008 | 08:29 PM
GT Griller's Avatar
damn...straight idle then punch it on street tires?...WOW
Old Nov 5, 2008 | 08:48 PM
Yes,every time i have stall it up it hase went slower by about .05 in the 60 and .15 in the end.
By leaving at idle it reduces the heat generated saving your tranny and it will also flash the converter allowing it to stall higher and get the rpm's where the should be.
Old Nov 5, 2008 | 09:24 PM
GT Griller's Avatar
Im more amazed at the fact that u can sixty 1.5's with street tires....lol
Old Nov 7, 2008 | 01:17 PM
Me too, many people said it couldn't be done. The was one guy that ran a 1.45 60' on the 245's perfedt track i'm sure.
The 1.59 was only once many other times i run 1.64 spinning slightly. I do want to get a full slick to see if i can cut consisted 1.57-1.58
OR... i could keep the 245 nittos for the sleeper look and buy drag shocks to see what it does.
Old Nov 7, 2008 | 01:18 PM
Another thing that helps with traction is getting weight off the nose suce as the bmr k-member i have and i removed the sway bar and bumper support and relocated the battery to the rear.
