Slap shifter
Old Nov 14, 2008 | 12:36 PM
Bluvette28's Avatar
Default Slap shifter
Just wondering if there are any slap shifters made for the auto transmission or any power transmissions that you have to shift.
Old Nov 14, 2008 | 09:58 PM
Bluvette28's Avatar
Anyone??
Old Nov 15, 2008 | 12:27 AM
thunderstruck507's Avatar
Not sure what you're asking...but my car has a b&m megashifter, its a ratchet shifter so no matter how hard you hit the thing it only moves up 1 gear at a time and has reverse locked out
not setup right yet, so i havent tried it on the ls1/4l60e combo, but with the old 350/700r4 it was awesome...the transmission wanted to shift itself at 4600, but with the transgo kit and this shifter I could hold it to whatever I wanted (5600) and bump and it would shift
Old Nov 15, 2008 | 05:31 PM
Bluvette28's Avatar
Where did you get that i havent found one for my car yet and ive been looking all over the place.? I have a 2000 camaro ls1
Old Nov 15, 2008 | 08:51 PM
TurboAv's Avatar
The B&M Pro Ratchet also only changes one gear at a time each time to bump it forward or backward. Jegs and Summit carry them.
Old Nov 16, 2008 | 09:53 AM
Bluvette28's Avatar
And that works with an ls1 camaro with the 4l60e transmission
Old Nov 16, 2008 | 03:47 PM
TurboAv's Avatar
The pro ratchet will work I think.
Old Nov 16, 2008 | 06:17 PM
Kingc8r's Avatar
Read this thread.....
https://ls1tech.com/forums/automatic...tall-help.html
Old Nov 19, 2008 | 10:16 PM
Bluvette28's Avatar
Thanks man that helped me alot. Is this the shifter that i can just slap into each gear though?
Old Nov 20, 2008 | 12:01 PM
Kingc8r's Avatar
You could but I don't think that is good for the 4L60E
Old Nov 20, 2008 | 02:53 PM
Bluvette28's Avatar
Why isn't it good
Old Nov 21, 2008 | 12:31 AM
Kingc8r's Avatar
I can't remember it clearly, but I think it is rough on the trans as it's not made to be manually shifted. I believe up shifts aren't as bad as down shifts........
