Torque Converter
Old Nov 14, 2008 | 09:45 PM
SSClone's Avatar
Default Torque Converter
Trying to figure out which brand converter to run. Any suggestions? Yank, TCI, Vigilante, etc. Going to pretty much be a all motor car, may spray it not for sure yet though.
Old Nov 14, 2008 | 10:00 PM
jsteele90's Avatar
yank 4400
Old Nov 14, 2008 | 10:23 PM
383lt1impala's Avatar
i have a performabuilt stall i love it u should look into them.
Old Nov 14, 2008 | 11:18 PM
cals400ex's Avatar
if you want to spray you will not want to go huge on the stall.
Old Nov 14, 2008 | 11:29 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Not nessisarily true. He just needs some good tires, a beefed up suspention and a progresive unit and he should be fine. Unless someone wants to chime in and correct me.
Old Nov 15, 2008 | 02:42 AM
Kingc8r's Avatar
Spray = Yank SS4000
N/A = Yank PT4000/4400
Go Big or Go Home!
Old Nov 15, 2008 | 03:05 AM
lemons12's Avatar
yes true....
if you go with a really big stall and spray it... it will blow through the stall... for instance..
if you have a 4k stall on motor.. it will flash to about 4300...
if you have a 4k stall on spray.. it will flash to about 4800...
thats not exact, just an example...
so you wouldnt want a 4600 stall on spray... you would wanna stay around a 4k.. or 4400 MAX..
(this of course is assuming you are using a regular shot.. something like a 100-150... bigger the shot, the higher the stall will flash..)
OP, Vig 4k is my vote.. i got it and i absolutely love it..
Old Nov 15, 2008 | 03:10 AM
rice4eatingnotdrivin's Avatar
if ur going to spray the car go with a yank 3600 stall... if ur going to run on motor vig 4000 stall... i dont no if other companies offer this but with vig u get 1 free stall change and a 2 year warranty..a converter is a big part of ur setup chose wisely
Old Nov 15, 2008 | 03:15 AM
lemons12's Avatar
why yank on spray and vig on motor?
i have a good reason why.... just wondering yours.. curious is all
Old Nov 17, 2008 | 10:24 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
If you are going to run n/a most of the time and the jug just once in a while then I would run a 4200 converter with with a 225 str. This will drive nice and still let you spray it without driving through it.A progressive controller is definately a positive!Give me a call and I can explain.1-866-726-8358. We also offer a free stall change on our converters and a 3 year warranty.
Thanks,
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Nov 17, 2008 | 12:08 PM
BobDoLe's Avatar
i have a 3600 2.5str performabuilt unit. i hit the spray and rpms jump roughly 300 with a 125shot.
i haven't sprayed it out of the hole, but only because i have no traction going wot in 1st.
