Need HELP tranny problem????
Old Nov 17, 2008 | 01:08 PM
1SIC_GM's Avatar
Default Need HELP tranny problem????
I have a built 4L60E tranny with a shift kit and a 3600 stall and yesterday I went to santa cruz and when I was parking I put it in PARK and I let my foot off the brake and it went REVESE.So I put it on drive and it kept going REVESE in every gear,but what I dont get is if it's on reverse and the shifter is in PARK it lets me take out the Key.When I turn it ON it wants to go REVESE. Any HELP to fix this????THANKS
Old Nov 17, 2008 | 08:25 PM
1SIC_GM's Avatar
Bump for the night crew.
Old Nov 17, 2008 | 08:30 PM
Tuffguy610's Avatar
It sounds like the cable has broken or become disconnected. I am no expert, but thats what it seems like. Your key coming out could be due to the fact that the starter key protection circuit relies upon the position of the shifter, and when you put it in park you will have the ability to take the key out. The shifter may be in the right position, but that doesn't mean squat if your cable linkage broke or became disconnected. Sounds like it broke with the transmission stuck in reverse. Since this happens, your car will think that its in park, thus allowing the starter to turn, but then the car goes backwards because the trans is stuck in reverse. This happened to my mom's old 88 Lincoln LSC, only the trans was stuck in park when the cable broke.
Old Nov 18, 2008 | 10:27 AM
1SIC_GM's Avatar
I will check it out today.Thanks appreciate it
Old Nov 19, 2008 | 12:38 PM
1SIC_GM's Avatar
Is my linkage shaft suppose to move in and out?and if its not is it expensive to replace?
Old Nov 19, 2008 | 12:41 PM
performabuilt's Avatar
LS1Tech Sponsor
A very small amount yes if much though the clip is missing that snaps on the linkage shaft between the case and the gate inside the pan , Easy fix though .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 19, 2008 | 01:49 PM
1SIC_GM's Avatar
Cool i'll take it to a tranny shop to do it or can i do it at home??
Old Nov 19, 2008 | 01:56 PM
LS1Tech Sponsor
Well if you have the clip or its in pan yes you could do it at home
__________________
Call 888-744-6542
Old Nov 19, 2008 | 02:23 PM
1SIC_GM's Avatar
Cool thanks for all your help.
