P1870 Code Fix?
Old Nov 20, 2008 | 11:26 AM
Black98T/A's Avatar
Default P1870 Code Fix?
My Torque converter isn't locking up and P1870 is (was) showing up. For reasons I still don't understand, it was causing a P0102 Mass Air low voltage code
https://ls1tech.com/forums/pcm-diagn...0102-help.html
.I took it to a shop for Diagnostics, the PCM was reset both codes are currently gone(no SES light yet) but the TCC still isn't engaging. I was thinking about putting a Trans Go shift kit in for firmer shifts anyway and heard it could fix the problem...anyone?
Old Nov 20, 2008 | 11:39 AM
performabuilt's Avatar
LS1Tech Sponsor
The transgo kit will address this as long as its not a converter or converter o ring on input shaft leaking or damaged issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 20, 2008 | 09:22 PM
Black98T/A's Avatar
Thanks...going to give it a try...just curious what's in the kit that can fix the problem?
Old Nov 20, 2008 | 09:49 PM
LS1Tech Sponsor
Theres a different valve for the TCC REGULATOR and a very stiff spring that pretty much disables PWM
__________________
Call 888-744-6542
Old Dec 14, 2008 | 03:53 PM
Black98T/A's Avatar
Ok...I had a Transgo hd2 kit installed and still no LOCKUP!
The trans jumps into 2nd a little quicker and firmer and I can hold each gear without shifting into the next if I shift manually(I don't remember being able to do that before) but that's all I notice.
My mechanic said the last two options are a new tcc solenoid or the torque converter itself. Trying the new solenoid first and hope it works, if not it looks like I'll be driving with more rpms on the highway and a SES light until I can swap a 6spd in.
Old Dec 14, 2008 | 05:38 PM
LS1Tech Sponsor
Sorry to hear you still have the issue, I probably would have swapped the TCC solenoid while I was in there just to be on the safe side, Beyond it you are indeed looking at either the TCC valve is stuck in pump, The o ring on the input shaft is damaged or missing and or the converter itself.
__________________
Call 888-744-6542
