Adjusting the line pressure???
Old Nov 22, 2008 | 02:47 AM
98Z28importslayer's Avatar
Default Adjusting the line pressure???
Im replacing both A and B shift solenoids tommorow (98 z28 A4 w/ stock trans) and my trans. guy also told me to raise my line pressure. First how would i do this? just turn where the star shaped tool gos into ? Also just by turning where the star shape tool gos into dos that just raise WOT line pressure or everything? and how much should i turn it? any advice is appreciated
Old Nov 22, 2008 | 03:03 AM
the_merv's Avatar
Veteran: Air Force
It's in the Tuning where you adjust the Line Pressures..
Old Nov 22, 2008 | 10:36 AM
performabuilt's Avatar
LS1Tech Sponsor
You can do it from the little screw on the PCS I would not go more that 1/4 turn it will raise the line pressure across the board including WOT. We use it to ajjust max line up o down on our dyno to get approx 225 psi max. which should be your goal
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 22, 2008 | 03:44 PM
that would be 1/4 a turn clockwise or counter clockwise ?
Old Nov 22, 2008 | 06:30 PM
LS1Tech Sponsor
varies but 10-20 % across the board up 1/4 clock wise and the same percentage down counter clock wise
__________________
Call 888-744-6542
Old Nov 22, 2008 | 07:47 PM
so if i turn it 1/4 clockwise it will raise the line pressure 10-20 percent across the table? sorry for all the questions i just dont want to mess anything up lol
Old Nov 22, 2008 | 08:39 PM
LS1Tech Sponsor
Yes and that the most i would consider going.
__________________
Call 888-744-6542
