transmissions Temperature
Old Nov 22, 2008 | 02:41 PM
slmawi's Avatar
Default transmissions Temperature
hello
i just rebuild transmission with aftermarket clutch and transgo shift
before
with Flex-a-lite Oil Cooler, 7 1/ 2 in. x 10 in
the Temperature is go around 200f on highway
after
with Flex-a-lite Oil Cooler and torque converter tci breakaway 2200-2400 stall
the Temperature go 230-240f on highway
just rebuild my transmission idon't wont it lost again
so its normal with torque converter or its high
and does i have issue with converter its work well
how to low my transmissions Temperature get bigger cooler
mod
3/4 headers
cold air intake
slp 160 deg Thermostats
compcam 224/230 .581/.592 114
Old Nov 22, 2008 | 03:03 PM
GT Griller's Avatar
No way should ur tempts get that high even on the highway.....Is this a 4l60e tranny? and are u sure its locking up?
Old Nov 22, 2008 | 03:35 PM
NHRAFORMULA00's Avatar
240 is really high for highway cruising.
Old Nov 22, 2008 | 06:19 PM
slmawi's Avatar
just try it after 12hours from rebuild
110km/h for 30min and the Temperature not high 190f thats alot of different
my be some dust do that?!
i will check the Temperature for week to see will go high
thanks
Old Nov 22, 2008 | 06:33 PM
performabuilt's Avatar
LS1Tech Sponsor
240 is a bit high , Where are you measuring temp at though? In the pressure port will generally run 20 degrees higher than actual temp. I would get a bigger cooler of course and make sure you have lockup. Where are you located and whats the ambient temperature there?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 22, 2008 | 08:41 PM
01ssreda4's Avatar
my car runs max 185 in 100 degree blazing heat sitting in traffic and thats coming from the pan. on the highway 160.
Old Nov 22, 2008 | 09:58 PM
slmawi's Avatar
from kuwait and temp. is 21deg c
my car built in trans temp sensor and after 12 from rebuild
110km/h for 30min and the Temperature not high 190f thats alot of different about 45f !! alot of temp change !
my lock up work and have smole issuse on 4th lock and and unlock and lock again some times do my tuner tune many time and thats a best result !
