shift kit or computer editing
Old Sep 22, 2003 | 03:54 PM
ss sully's Avatar
Default shift kit or computer editing
which one works better, a shift kit or using a computer to boost up the pressure in the lines? can u get a shift kit and do programming?
Old Sep 22, 2003 | 04:11 PM
Colonel's Avatar
Default Re: shift kit or computer editing
Shift kit. Programming really doesn't boost shift firmness at WOT since you're at 100% line pressure at WOT anyway. Programming doesn't take care of many of the issues that a shift kit does either (to do with the timing and speed of several different things.)
Regardless of if you have a shift kit or not, I would recommend leaving the tranny line pressure alone or at least not raising it much.
TCI makes a great shift kit that is easier to install than a Transgo but is just as effective.
