Manual Valve body for 4L60E
Old Sep 22, 2003 | 07:11 PM
flyinZ's Avatar
Default Manual Valve body for 4L60E
Just wondering if anybody has seen these before?? Any company making them?? I talked to a guy in Canada, and he said a company up there, fabricated a manual valve body for the 4L60...Just wondering if anybody else has seen this..
Old Sep 23, 2003 | 08:56 AM
GreekZ's Avatar
Default Re: Manual Valve body for 4L60E
TCI makes a reverse manual valve body. Jegs
sells them for $269
Old Sep 23, 2003 | 09:19 AM
gator's 99TA's Avatar
how would this be beneficial? just wondering
Old Sep 23, 2003 | 10:52 AM
SS00Blue's Avatar
For boosted guys, like me, I could launch on 5 pounds instead of the 1 pound I get by the foot brake.
For NA, they can load up the convertor closer to the flash stall.
Bottom line is better 60'. Maybe a 1.4x??
SC-
Old Sep 23, 2003 | 11:27 AM
MEAN LT1's Avatar
SC-
It sounds like your talking about a two step.
Last time I checked, all a manual valvebody did was let you shift your own gears without the computers assistance.
Old Sep 23, 2003 | 11:30 AM
GreekZ's Avatar
Yeah, that sounds like a trans brake set-up. The
benefit of having a manual valve body is firmer
shifts and full line pressue but that could be a
bad thing.
Old Sep 23, 2003 | 12:51 PM
Rob98Z28's Avatar
Hey FLYINZ, it was probably me you talked to up here in Canada about the manual
valve body. My transmission guy at the GM dealer I work at had one fabricated for
me in conjunction with a shop he always deals with. I think I still have your e-mail
address. If you want, I could find out exactly were he got it and pass on the phone
number to whomever it was if you're interested. Just let me know. Keep bugging me
on it if you are. Time is so limited for me right now, but I'll do what I can!
Old Sep 23, 2003 | 02:13 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Ask Chuck at FLP he has a local Chicagoan with a 4L60E with a manual valve body rolling around.
Old Sep 23, 2003 | 02:23 PM
Silvr98z28's Avatar
Yes, that would be me. And very pleased this far. Just ran 10.96 at 123.2 with a 1.51 at 3340lbs.
Little more fun shifting too.
Old Sep 23, 2003 | 07:56 PM
maddboost's Avatar
Do you think its really faster with you shifting? Do you have any kind of lock so you dont shift into OD or reverse?
Old Sep 24, 2003 | 10:42 PM
sleepersilverado's Avatar
does the tc lock up still work the same. basicaly it is like shifting your auto but it will hold all gears till shifted.
i have been cusious about this for a while and it made me wonder over here. my friend has a th 350 with revers pat man valve body and a break. i love his setup and would like something similar but dont want to loose the mileage with no od or lock up and also loose the speedo.
Also what are all the options because i do not want to be rebuilding 4l60e's every year. but want to keep the daily driver aspect.
Thanks
Old Sep 24, 2003 | 10:52 PM
Silvr98z28's Avatar
Not faster,I just like having the control. As far as any lock, no I am using the stock shifter. Works fine for me.
Old Sep 24, 2003 | 11:07 PM
Ragtop 99's Avatar
Is the FLP unit on the market or is yours a prototype or test unit?
Old Sep 25, 2003 | 06:58 AM
Silvr98z28's Avatar
It's not the 1st. But I think that I am the only one actively racing on one.
Old Sep 25, 2003 | 11:59 AM
SS00Blue's Avatar
Oops, my bad. I was thinking Trans Brake. Sorry.
SC-
