Car won't shift out of 1st
Old Nov 24, 2008 | 11:24 AM
norman99zx9r's Avatar
Default Car won't shift out of 1st
Have the new crate motor installed and hooked to the transmission. It is a LS1 engine with a 4L60E transmission and a 2000 camero wiring harness. I have all the wires (i think) hooked up correctly and we took the car out for a test drive but it wouldn't shift out of first...? I am stumped here, any ideas or areas i can check before doing a major re-check of everything.
Thank you.
Andy
Old Nov 24, 2008 | 12:20 PM
performabuilt's Avatar
LS1Tech Sponsor
Is the speedometer working? If you dont have a VSS signal the trans will not shift.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 24, 2008 | 01:23 PM
the_merv's Avatar
X2..check your connections.
BTW..
Camaro..
Old Nov 24, 2008 | 05:11 PM
Ok will do, thank you, make sense for sure, i will have to check the speedo.
