Problem with brand new trans, Need Help!!!!!
Old Nov 24, 2008 | 10:51 PM
Bellflower's Avatar
Default Problem with brand new trans, Need Help!!!!!
We installed a brand new FLT level5 trans tonite, Runs great in 1st and 2nd, but slips like crazy as soon as it goes to 3rd.. Could it be something electronic or in the converter is is something wrong in the trans????
(if it make a difference, the trans was installed in a 2000 silverado w/ LQ9 6.0 w/ cam and heads)
Old Nov 24, 2008 | 11:06 PM
calongo_SS's Avatar
Have you tried talking to them? That's probably the best thing to do. Running straight to the keyboard isn't always the best course of action.
Old Nov 24, 2008 | 11:08 PM
performabuilt's Avatar
LS1Tech Sponsor
I would agree talk with FLT first if there is a problem they will take care of it . Its hard to say what may have happened .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 24, 2008 | 11:48 PM
Bellflower's Avatar
Default Flt
Im not ******* them by any means, just hopping somebody could maybe give us an idea tonite while were still working on it, FLT isnt open now, but were gonna call them first thing.
Kinda think its electronic at the moment.
Old Nov 25, 2008 | 11:25 AM
FLT's Avatar
FLT
We have been in contact with the shop that installed the trans. It appears that their's a TPS low voltage problem with PO122 being set. We do have the shop checking into it and will see what they find. Hopefully the trans isn't damaged, unfortunately the TPS is most the important input the pcm looks at for line pressure increase.
Old Dec 2, 2008 | 08:46 AM
Bellflower's Avatar
Default FLt
We were in contact with FLT, they were extremley helpful, turned out to be a broken wire for the speed sensor. Got it fixed and it works like a champ
Old Dec 3, 2008 | 08:01 AM
FLT's Avatar
FLT
Glad we could help your shop out with this one, besides your TPS problem we didn't know that you had a VSS problem as well! Those two problems combined would definitely make a transmission not shift properly. Now you can understand why we have that pretty blue piece of test equipment in our signature and on our website. Quality control is #1 here at FLT!
Chuck
