what cooler and transgo ??
Old Nov 27, 2008 | 10:03 AM
smamar's Avatar
Default what cooler and transgo ??
Hey I have a 4l60e in my 02 trans am with a yank 3600 stall (2.3 STR)
and i´m gonna add a trans cooler, what cooler should i get ?
i was thinking 24.000 b&m cooler ??
but what do you guys think, and do i need a fan ?
i´m also going to buy transgo hd2 shift kit !! should i buy this one ?
http://store.summitracing.com/partde...=trg-4l60e-hd2
what else do i need to buy, if i´m going to have a trans gauge to ?
i´m gonna let a transmission shop do it for me... i just have to buy the stuff !!
thanks
Old Nov 27, 2008 | 04:51 PM
bigfatls6's Avatar
i am wondering also whats the best shift kit to buy?
As far as the cooler goes buy the Hayden plate and fin style part number 1679. Its rated to be used on vehicle with a gross weight up to 30,000 lbs and will keep your transmission cool. Its up to you to do the fan or not. I put one on my last cooler just because it was really easy to do and cheap. I bought an electric fan on ebay for like $15. You can get the hayden cooler for around $50. The fin and plate style coolers are the best to use also.
Old Nov 27, 2008 | 09:29 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
I use the 24K B&M cooler, with no fan coupled to a 3 qt deeper trans pan, it keeps eveything nice and cool.
SteveC
Old Nov 27, 2008 | 10:52 PM
00_Z-28's Avatar
I would say the fan is not needed. Just depends on where you mount it I put mine right in front of the radiator and mine stays plenty cool with no fan.
Old Nov 27, 2008 | 10:59 PM
jsteele90's Avatar
SteveC
same setup i have. trans has never gone over 165 degrees
