Converter
Old Dec 8, 2008 | 11:13 AM
jjenkins's Avatar
Default Converter
I'm thinking of going with one of Circle D's 11" 3200 converters, since my car is only on the street with street tires. Anyone have additional advice?
Old Dec 8, 2008 | 12:35 PM
SSmoken's Avatar
trans cooler and some tires.
Old Dec 8, 2008 | 12:46 PM
00_Z-28's Avatar
+1 on the trans cooler and a shift kit would be a good idea as well.
Old Dec 8, 2008 | 02:31 PM
Badazz 97 TA's Avatar
why not cut some rotational weight and go with a 9in stall?
Old Dec 8, 2008 | 02:49 PM
WHPLASH's Avatar
Trans cooler and a Transgo kit is a must in my book. Go with a Yank!!!
https://ls1tech.com/forums/lsx-parts...converter.html
Old Dec 8, 2008 | 02:57 PM
FormulaZ's Avatar
Mine is a dd as well and going with the Circle D 9" 3400 stall. Had a yank 3200, just needed a trans cooler. Id recommend a shift kit as well.
Old Dec 8, 2008 | 06:35 PM
KameleonTransAm's Avatar
Probably because this one is $3XX as opposed to $6XX if I had to guess.
To the OP: I'm in the same boat and have been considering the same stall. What's weird is they used to call it a 3000, now recently they are referring to it as a 3200.
Old Dec 8, 2008 | 06:56 PM
chevyz2801's Avatar
I'm thinking about selling my pro yank 3400 only 7k mi on it make offer.
Old Dec 9, 2008 | 06:12 AM
jjenkins's Avatar
That is so true the price of the 9" is $675 as to only $350 for the 11". I am just trying to get rid of the deadzone in my car between 25mph and 50mph. Does anyone out there have an 11" and how do you like it?
Old Dec 9, 2008 | 06:49 AM
omcar's Avatar
I had a yank 11" 3,200 super thruster converter and loved it.
Old Dec 9, 2008 | 06:53 AM
98Z28CobraKiller's Avatar
Restricted User
9" is way too much stall. 3200 is not enough stall IMO. A converter that costs less than $500 has to be a POS. This is not something you want skimp on. If that converter lets go, it's probably gonna take the tranny with it. Save up another couple of hundred and Call Greg @ FTI. They'll build you a premium converter for a bargain price. They're a sponsor.
Old Dec 9, 2008 | 06:59 AM
WHPLASH's Avatar
I agree. You get what you pay for. Not something to skimp on.
Old Dec 9, 2008 | 08:53 AM
Circle-D's Avatar
The 11" 278MM is a converter out of a TB I6 reworked to Circle D Specs. It is rated at 3000-3200 stall. It is a few pounds lighter than OE. The reason it is so inexpensive is because it is based off an 4L60 converter and does not require a lot of parts, ie - no billet front. This converter is very durable, stronger than the OE converter, better clutch and tig welded. It is designed for the mildly modified street car who wants a good budget converter.
The 9.5" 245MM Billet converters are more performance oriented. Much lighter, they only weigh about 30LBS. They will produce better results on the track and street. But they don't have the same street manors or price as the 11" converter.
Each converter has it's pros and cons, just depends on your needs and wants.
Chris
Old Dec 9, 2008 | 09:38 AM
01ssreda4's Avatar
something I try to remind people when talking about shift kits is that most if not all shops may not wanna pull your 60 apart to fully install it. the local shops here said they wouldn't pull mine apart without a freshening up. either choice from circle d sounds like a good choice. i personally would go with the nine inch converter though. do it once, do it right.
