4L70E question
Old Dec 15, 2008 | 01:24 AM
QucikSilver's Avatar
Default 4L70E question
Can I use a 4L70E in a 2000 Trans Am? Will all the electronics work with my LS1 computer. Will it mess with my tune any?
Old Dec 15, 2008 | 05:59 AM
FLT's Avatar
FLT
The electronics are a bit different if the 70 has an input speed sensor. However it will work without a problem. You will have to change the shift linkage shaft and maybe the tail housing if you are using a torque arm that is bolted to the tail housing. Vince
BTW I swear I answered this same question yesterday did you delete your thread? Vince
Old Dec 15, 2008 | 08:39 PM
so all I have to do is change the shifter rod that goes into that transmission and it will work fine.
Actually no I did not delete any thread. this is just a coincidince
