Shif kit or .490" boost valve?
This seller includes the .490" valve as well as other valves + gaskets:
http://cgi.ebay.com/ebaymotors/TRANS...QQcmdZViewItem
This is just the .490" valve, no gaskets? Which ones do I need other then pan?
http://cgi.ebay.com/ebaymotors/NEW-4...QQcmdZViewItem
http://www.jegs.com/i/TCI/890/374420/10002/-1?CT=999
Does the valve body need to be removed for this installation?
Thanks
In the other auction, (The boost valve only) is a problem solver type that has o-rings around the OD. It's the same size as stock.
If you change only the valve I seriously doubt you're going to feel any difference at all.
