A4 Launching Question
Old Sep 29, 2003 | 06:23 PM
strobelite's Avatar
Default A4 Launching Question
What's better from the line, reving it up high and then slamming it in first and taking off, or just put it in 1st from the start and rev it to about 2 grand and launching, I've tried both dont know which is better
Old Sep 29, 2003 | 07:15 PM
Got Me SOM's Avatar
Default Re: A4 Launching Question
if you are slammin it in first, you are a dumbass. you're transmission already is weak as it is.
Leave it in drive and stall as high as the rear tires will let you. Some converters like to be "flashed" which means taking off from idle and then stomping on the gas pedal.
I would stall it up and tighten up the drivetrain then go. stall up to 1500 or so.
Old Sep 29, 2003 | 07:33 PM
strobelite's Avatar
Thanks for you input, im a newbie ya aint gotta go calling names, thats cool though thanks bud, 1 more question, going from drive is quicker then shifting manuely out of 1st?
Old Sep 29, 2003 | 09:53 PM
NightHawk's Avatar
Subtle as a sledgehammer
AFAIK, as long as there is nothing wrong with your shift points, it's best to just put it in drive and leave it there. If you hold first, you run the risk of bouncing off the rev limiter.
Old Sep 30, 2003 | 12:35 AM
Jabroni's Avatar
That's it. Brake torque it against the converter and load the drivetrain. On green, sidestep the brake and hit it!
Old Sep 30, 2003 | 12:48 AM
ALPINE's Avatar
While stalled, then tappin a bit more, releasing then hittin it worked best for me in my A4.. 2cents.
Old Sep 30, 2003 | 02:39 AM
unit213's Avatar
Administrator
Eveyone above is right. Here's my 2cents...
Your tranny is a 4L60E meaning it shifts electronically. Shifting manually can damage it actually. I did that my first few runs too since I didn't know any better.
On stock radials, drop the tire pressure to around 24psi and pump up the fronts to around 40psi. Load the drivetrain by stalling the coverter ever so slightly...no where near 1500rpms. Stall it just enough to tighten up the drivetrain. On the third yellow count "one-one thousand" as you roll quickly into the throttle. That'll prevent major tire spin. Stomping the gas will break the tires loose and you'll cut 2.1 60's. I was able to cut 1.9's with the technique above.
Launching on DR's or ET Streets with a converter is a whole 'nother ball game.
Good Luck!
Old Sep 30, 2003 | 03:16 AM
35th SS's Avatar
finally got the hang of it on nittos.20psi of air and linelock it for about 4-5sec.burnout.load it up just a bit and go.work for me.
Old Sep 30, 2003 | 04:39 PM
Fast Eddie's 02 T/A vert.'s Avatar
Listen to the (Big Unit) 213,that's what i did and he's right on.I took first place last friday night only because i was able to launch my T/A with out spinning my tires at all..i have it down,i only give enough throttle to take up the slack in the drivetrain,it's pretty simple with an A4...just can't get over excited while staging...stay cool.
Old Sep 30, 2003 | 08:09 PM
unit213's Avatar
Administrator
I actually took that advice from Colonel if I remember correctly. Not that he knows anything about drag racing. I tried several different methods and that worked best for me.
Old Sep 30, 2003 | 08:25 PM
strobelite's Avatar
I feel slow off the line, is that normal?? lol. What can I do to make me quicker
By Brett Foote | 2026-06-04 05:00:17
