what size stall no cam
Old Dec 29, 2008 | 03:59 PM
DeltaChi5674's Avatar
Default what size stall no cam
Ok so I have a stock trans am and my transmission has gone out. I do not have a cam but I don't know if i should put in a big stall. I will put in a cam but it will be a year or so. What stall size do you recommend? This is a daily driver.
Old Dec 29, 2008 | 04:13 PM
Elliott's94Z's Avatar
I would look into the Yank SS3200 or the SS3600 for a daily driver.
Old Dec 29, 2008 | 04:16 PM
TXZ28LS1's Avatar
popular choices for daily driver stalls are 3200-3600!! but there are guys who daily drive 4k stalls with no problems.
Old Dec 29, 2008 | 04:33 PM
Camaro396's Avatar
What size cam do you plan to do in the future? What are your future goals with the car? A converter is something you want to do once and do right.
Old Dec 29, 2008 | 04:43 PM
Circle-D's Avatar
More info needed about the cam choice so you will be ready when you get it. But 3500+ is very normal for DD LS cars. 3200 is the minimum I would go, but if adding a cam it might not be enough.
Chris
Old Dec 29, 2008 | 05:45 PM
omcar's Avatar
Vigilante 2,800-3,200 is a good choice.
Old Dec 29, 2008 | 05:59 PM
Camaro396's Avatar
No its not.
Old Dec 29, 2008 | 06:16 PM
Kingc8r's Avatar
3600 or more.....
Old Dec 29, 2008 | 06:17 PM
The car is stock but i will be putting lt's and an intake in next month and maybe a few other bolt on's over the next year. Then i want to put a very mild cam in next year.
Old Dec 29, 2008 | 06:26 PM
Camaro396's Avatar
I'd go with a 4000, if those are your plans.
Old Dec 29, 2008 | 06:28 PM
jetlag's Avatar
I agree, if you're a 14 year old girl.
Old Dec 29, 2008 | 06:50 PM
Originally Posted by jetlag
i agree, if you're a 14 year old girl.
lmao
Old Dec 29, 2008 | 06:52 PM
GOR1LA's Avatar
i got a 3k vig stall i have had no problems
Old Dec 29, 2008 | 07:09 PM
01ssreda4's Avatar
ha ha. i went 3200 (no cam) and still had some dead spots. i could tell it needed at least a 3600. now with a 224 cam it has the power to pull through the dead spots better.
Old Dec 29, 2008 | 08:48 PM
sr71's Avatar
my engine is stock and I have a ss3600 and a set of 3.73 gears. it is a great driver.
Old Dec 29, 2008 | 10:17 PM
00_Z-28's Avatar
I love m 3200 but if i had to do it again id go 3600 DD here also
Old Dec 29, 2008 | 11:15 PM
well i guess ill just have to give the 3600 a try iv heard too many people say they would go bigger. Thanx for the help guys
Old Dec 30, 2008 | 01:16 AM
SSmoken's Avatar
4000 stall here in my dd. stock car.
Old Dec 30, 2008 | 07:13 AM
Circle-D's Avatar
For that I would say our 3C or 4C. Either will be fine for a DD, with the 4C giving a little better results at the track. I would suggest the Stage I Billet Street/Strip Series for either stall. Good Luck with your decision.
Chris
Old Dec 30, 2008 | 11:25 AM
bigboykilroy's Avatar
Yank SS4000 with 3.90 Gears......love it !!
