m6 to a4 swap wiring question
Old Dec 30, 2008 | 03:48 PM
10secondZ's Avatar
Default m6 to a4 swap wiring question
Does anyone have the wiring schematics for a 99-00' harness for the reverse, brake lights, PNP and the other switch? (lock out maybe). Any help would be great! I looked at the thread above, but only 02' specs where there.
Carter
Old Jan 1, 2009 | 10:51 AM
ShevrolayZ28's Avatar
The reverse light switch is on the mid-passenger side of the M6. Look at the harness and you should be able to figure it out. (To see if you have the correct wires, touch them together and the reverse lights should come on.)
Connect the 2 reverse light wires to either side of the switch on your shifter and you're all set. BTW, you can buy a weatherpack connector at the average parts store that will plug right into the existing reverse light connector.
As for the PN wiring.... You need to access the wires going to the switch on the clutch pedal. Tie them together and your car will start in any gear. Connect them to the shifter's neutral safety switch, and the car will only start in P or N.
Leave the brake lights alone. Nothing needs to be changed for those.
Old Jan 1, 2009 | 03:01 PM
10secondZ's Avatar
Thanks! That is exactly what I needed!
Old Jan 14, 2011 | 09:19 PM
LT1Formula007's Avatar
just needed that lil info.
marking this page.
