4L60E shift kit installation question
First off, I do not think I received the "large white" spring that the instructions tell you to replace in the valve body/actuator valve. I had all other springs to do job but that one. I am positive I did not drop it, does anyone know where a actual picture of this spring is on the internet so I can see if I had it or not?
Second, on the new 1-2 shift valve there was a tightly wound spring (no air gaps) on the end, not fully seated, but partially. On the directions it showed no extra spring on the end, just the stock/reuse spring.
My main question is, what are you supposed to do with this tightly wound spring, I assume the stock/reuse spring might go over this spring, im not sure and just installed it with out the tightly wound spring (nothing seemed right when using it, so I choose safe then sorry)
OK the kit you got is complete and is not missing anything. I talked to the transgo guy and he said that the some of the parts in the video have been removed in the kit because they proved to not really do **** for the trans.
-Do exactly what the directions say- Not fukin around here
IE Drill the wholes use the springs supplied and take your time.
You do not have to remove the trans bud. I think thats what your talking about in regards to the components in the pump. I had to beat on the floor a bit to get at it, nothing extreme. If you need some advice send me an email to Ch6v9lle@yahoo.com and I will give you me cell number.
transgo # 6264437451
Joe
So what exactly do I have to do to install the big bag of springs? I believe these are the springs for the 3-4 burn up problem.
I think transgo is closed today. I need to order a new tightly wound spring and large white spring.
Why do you need to order new springs?
The bags of different colored springs go inside the trans, not in the pump, they go in the input drum.
I got to the pump on my 01 camaro without removing the trany. I just had to hammer the floor over a bit. Nothing extreme. Just saying it can be done. I think I made about an inch of room for the foreplay.
There is no way you could remove the pump while in the vehicle. I think you might be thinking of the servo. Here is a photo of where it is located.
This is where the pump is located.
Oh yea and I had an oh **** moment because I removed the converter clutch valve... I moved just before it shot out. It had some serious pressure on it....
By the way, do you think my seperator plate gaskets will be reuseable after taking it down again?
