TH350 help
Old Jan 5, 2009 | 12:14 AM
GreenBlood's Avatar
Default TH350 help
so, as in my WTF did i break thread, my 4l60e took a ****. I have a chance to pick up a freshened TH350 with trans brake and BTE 3800 N2O converter. The guy wants 750 for the trans and converter. Now, i read the sticky with the link to the swap, but I am confused as to what parts i need to get this trans to work. Where can I buy a new DS, or should I have mine shortened? What torque arm should I use? Should I buy a crossmember, or modify the stocker? What parts do I need to get the trans to link with the LS1 flexplate? What should I do about the PCM, do I just get the codes for the trans shut off? Thanks
Old Jan 7, 2009 | 08:26 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The driveshaft is going to have to be lengthened and a few sponsors sell them. You can do one of four torque arm setups- 1) buy the conversion kit from B&M and keep the stock ta. 2) Buy a crossmember with the relocation mount on it (BMR and UMI sell them) 3) Buy a ta that mounts in the middle of the car 4) Buy a tunnel mount ta from Jegs. I have a UMI crossmember and it is an awesome piece and is priced right. I also have a TCI flexplate that has a dual bolt pattern for a TH350 and 4L60E. I took all the ECM crap out of my car so I can't help you there.
Old Jan 8, 2009 | 08:49 AM
UMI Performance's Avatar
Hello,
We will be glad to help you with the torque arm and crossmember.. we have a few different options I will post and go over below.
1. If you run a short tunnel mount torque arm all you would need is a transmission crossmember designed for the TH350, this can be seen here- www.umiperformance.com/2211
The short tunnel mounted torque arms can be seen here- All will work with any transmission/
www.umiperformance.com/2200
www.umiperformance.com/2201
www.umiperformance.com/2202
www.umiperformance.com/2203
2. We also offer a transmission crossmember with a built in torque arm mount for the TH350. This features the correct mount for the TH350 and has a integrated torque arm mount to mount the factory torque arm or any factory style aftermarket torque arm. This item can be seen here- www.umiperformance.com/2212
If you have any questions please ask. Thank you!
Ryan
Old Jan 10, 2009 | 09:31 AM
sedanman's Avatar
Z28/2002 hit it pretty right, but the driveshaft depends on the output shaft if its a 6" it will need to be lengthend if its a 9" the stock driveshaft will work.
Old Jan 11, 2009 | 11:44 AM
9sec93's Avatar
you can also use a stock 98 flexplate if you want to save money. either way you need to use the pilot adapter for the crank to center the torque converter in the crank.
Old Jan 11, 2009 | 12:47 PM
Camaro396's Avatar
The TCI flexplate comes with the Flexplate bolts and the spacer for adapting the converter. However, if your converter was built LS1 specific for a LS/TH350 car, you won't need this. But if you are using a standard old school SBC/BBC TH350/TH400 converter, you will need to put this spacer on.
Old Jan 11, 2009 | 04:07 PM
9sec93's Avatar
i just bought a tci flexplate last week and it didnt come with the bolts or spacer. maybe they arent including this stuff anymore. no big deal for me since i already had the spacer and ARP bolts.
Old Jan 11, 2009 | 06:26 PM
Z28/2002's Avatar
Thanks for including the stuff I left out guys
Old Jan 11, 2009 | 07:21 PM
Camaro396's Avatar
Weird. I got mine about a month or so ago. Thats odd.
Old Jan 12, 2009 | 12:29 AM
9sec93's Avatar
damn it......i guess that means
