Full manual Trans go kit
Old Jan 9, 2009 | 12:09 PM
w3s1c0a5t's Avatar
Default Full manual Trans go kit
WOW. This is PITA. Were putting it in right now. You have to modify everything.
But when it firms up all the shifts and makes it a lot more fun to drive on the street it will be worth it. And it saved me from having to tune right away with 4.10's and the stall.
If anyone is curious i can snap a few pics as to what all goes in this thing.
Old Jan 9, 2009 | 01:33 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Should've tried ours.
http://www.trinitytransmission.com/l80manvb.html
Old Jan 9, 2009 | 02:29 PM
devinfbody's Avatar
It says that mvb is for the 4l80e. Does it also work with the 4l60e?
Originally Posted by tptransmission
Old Jan 9, 2009 | 03:04 PM
Thought you were referring a 4l80e. Starring at this computer too much..
Old Jan 11, 2009 | 01:41 AM
w3s1c0a5t's Avatar
Ya i ment a 4l60e... This things is crazy... It better be worth it.
Old Jan 11, 2009 | 01:12 PM
devinfbody's Avatar
How are you planning to retain torque converter lockup? I've read alot of answers to this question but none seem to be 100% sure.
Old Jan 11, 2009 | 02:06 PM
performabuilt's Avatar
LS1Tech Sponsor
Actually thats easy of you are allready and auto car. Simply leave the 1-2 and 2-3 along with the 3-2 and PWM solenoids unplugged. Then plug the harness in from the car and use a tuner to remove the test for all solenoid codes, Once this is done the PCM will turn lockup off and on just like you are a full auto when you are cruising around.,
It is a good idea though to set it up for above 45 mph in 4th gear only ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 11, 2009 | 02:43 PM
devinfbody's Avatar
That was the only thing making me not want a full manual kit. Thanks for clearing that up for me. Now what about line pressure. Is the computer still able to control that? Or do you need a vaccum kit?
Oh sorry for the hijack, keep us posted on how it turns out.
Old Jan 12, 2009 | 01:31 PM
w3s1c0a5t's Avatar
Kits fully in. I plan to wire up a switch so i can manually lock the converter. In the trans go kit theirs a vaccum kit. You have a T fitting that you put in the brake booster. I should have Some results before the end of the week. Maybe an in car vid for those considering the kit.
Old Jan 12, 2009 | 01:53 PM
LS1Tech Sponsor
That kit comes with a vaccume modulator kit in it so you can used that or you actually can still use the PCS your choice.
__________________
Call 888-744-6542
Old Jan 12, 2009 | 02:03 PM
devinfbody's Avatar
Cool, I'll be waiting for that video.
Old Jan 17, 2009 | 10:41 PM
w3s1c0a5t's Avatar
Well its in. I got a little wheel time in the car. Its great. Better than i thought it was going to be. If you can make it thru the install i recommend it for anyone running around on the street. Im sure if the track is where you live you would want to computer to keep doing its thing. Im always going to live for the street tho and its works great their.
Old Jan 17, 2009 | 11:08 PM
LS1Tech Sponsor
It does work very well really , we have something in the works that will give best of both worlds soon
__________________
Call 888-744-6542
Old Jan 17, 2009 | 11:49 PM
themack56's Avatar
Originally Posted by performabuilt
it does work very well really , we have something in the works that will give best of both worlds soon
like????????????????
Old Jan 18, 2009 | 02:13 AM
LS1Tech Sponsor
time will tell towards summer
__________________
Call 888-744-6542
Old Jan 18, 2009 | 12:17 PM
w3s1c0a5t's Avatar
Oh and Thank you guys very much. I gave you guys a call on a SATURDAY. And your tech support still took care of me. The customer support you guys have is top notch. I promise you guys will get my refferal if anyone asks
Old Jan 21, 2009 | 09:15 PM
w3s1c0a5t's Avatar
Well I really got some seat time with this now. This with the stall and gear i chose make the car a blast to drive. I Need to touch up a few things in the car But god its really fun. No more kickdowns or flat spots. Lots of fun.
