Trans cooler lines
edit: I just relized thats what the guy above me said.
With any fluid to fluid heat exchanger, the two fluids flow in opposite directions.
Radiator coolant flows down, trans cooler fluid flows up.
My point is this. This is an LS1 site, no one ever gives specific details so I'll assume the guy has an LS1 4L60E.
Fluid comes out of the bottom fitting on the trans, you connect the bottom fitting on the trans to the bottom fitting on the radiator, now fluid is going to come out of the top fitting of the radiator, then you take that top fitting of the radiator and run it to the top fitting on the trans.
You can't explain it easier, but you can over explain it and list how every trans made flows and confuse the hell out of the OP.
I just try to answer the question being asked.
Yes, I do see other questions about other transmissions, but they are in other posts, not this one.
But thats just me simple question---simple answer.
Anyone wonder why my user status says restricted? It's because of this post
A guy asks a question, I answer with a simple yes.
And no one understands, until the very end.
So maybe you are right, post all the info you've got because people will continue to misunderstand, take words out of context, not provide enough (if any) information, etc. And someone will get mad because you either went out of your way trying, or didn't type enough words and use enough cute little smilies.
Out the lower port of the transmission, into the bottom port of the radiator/cooler, out the top port of the radiator/coolant, back into the top port of the 4L60E. Correct?
Now, what if you add an aftermarket tranny cooler, what should be the specific route?
Assumption: After it comes out of the top port of the radiator/cooler, it should go into the aftermarket cooler, (Lower port if mounted in that fashion.), out the top port of the aftermarket cooler, & then back to the top port of the transmission?
(Using the aftermarket cooler as a 'secondary' cooler?)
Most recommend bypassing the radiator cooler. But if you do install an auxillary cooler, most recommend splicing it into the line that exits the top of the radiator.
Makes more sense to me that way, ...
BTW, I know the auxilary coolers don't normally have an 'inlet' & 'outlet', but I stated it that way simply because of the mounting position that was noted.
extra btu removal? what if you generate 10,000 btu's and can remove 40,000 btu's?
i'm not seeing the need to get that scientific about a trans cooler.
i'm also done talking about this.
