trans temp gauge
Old Jan 12, 2009 | 09:40 PM
9000th01ss's Avatar
Originally Posted by ilovemywhitepony
How do you read the trans temp with hptuners?
You open the table display and select the trans temp PID.
I reads off the factory temp sensor in the trans.
Old Jan 12, 2009 | 09:43 PM
9000th01ss's Avatar
Originally Posted by tptransmission
Your welcome, tried not to stray to far off topic.
Yes, I sure did go
Old Jan 13, 2009 | 03:46 AM
98 WS6's Avatar
Wait so is there somewhere in the wiring or pcm that you can tap into, since there's a stock temp sensor?
Old Jan 13, 2009 | 04:30 AM
the_merv's Avatar
Veteran: Air Force
^^It's a Wire in the bunch that go to the Tranny.
It goes to the PCM, see if you can find you a pinout and look. I have it on my Computer at home..
Old Jan 13, 2009 | 09:44 AM
9000th01ss's Avatar
I'm guessing you can't just connect a gauge to that and get a correct reading.
Old Jan 13, 2009 | 11:58 AM
tptransmission's Avatar
Closed ex-Sponsor Account
The pins on the transmission are L & M. L is the 5 v reference and M is the ressitance to Ground the the PCM uses. Your gauge would have to match the Temperature vs resistance for the internal sensor.
Old Jan 13, 2009 | 12:46 PM
9000th01ss's Avatar
You can get an Interceptor gauge, plug it into your OBD port and read every sensor on the engine and more.
Old Jan 13, 2009 | 12:48 PM
9000th01ss's Avatar
Forgot to say, it says these are easier to install than regular gauges, just put the gauge in the pod, and plug it into the OBD port.
Old Jan 13, 2009 | 04:03 PM
98 WS6's Avatar
That looks like it would cost a buttload lol. Sorry for the newbness, where's the OBD port?
Old Jan 13, 2009 | 04:17 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
its the plug were you tune your car/scan for codes
Old Jan 13, 2009 | 06:44 PM
9000th01ss's Avatar
It's right around your right knee when driving.
I think the two gauge kit costs right under $400, and theres a single gauge kit for $240-$250 I think.
Old Jan 13, 2009 | 06:54 PM
  #32
shtnfrds's Avatar
That is the best place to put it if you want a true sump reading, although it is a pain to do.
Anything done the proper way on these cars is a pain anyways.
Old Jan 13, 2009 | 10:26 PM
  #33
Defineatly more accurate then the production sensor. May be cheaper as well than the OBD method as well.
