upgrades to 4l80e?
Old Jan 11, 2009 | 04:47 PM
crf538's Avatar
Default upgrades to 4l80e?
i just got a 4l80e and im going to get my local trans guy to go through it for me, what should i get him to upgrade while he is in there?
its going in a turbo car thats about 700fwhp i would estimate and im thing about getting that trinity trans brake for him to install while he's in there
thanks for any input.
Old Jan 11, 2009 | 07:00 PM
WE TODD DID's Avatar
He is the transmission guy, I would think he should tell you what you need??
Old Jan 11, 2009 | 07:35 PM
Randy WS6's Avatar
What year is it ? It on the yellow tag.
Old Jan 11, 2009 | 08:48 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Let me know what we can do to help! I can make your 4l80 perform better than anyone else.
Old Jan 11, 2009 | 09:03 PM
crf538's Avatar
sending pm
Old Jan 11, 2009 | 09:19 PM
Randy WS6's Avatar
You cant beat that
Old Jan 12, 2009 | 10:14 AM
nahasapeemapetalon's Avatar
I highly recommend the Stage II transgo shift kit. 100% better.
Old Jan 12, 2009 | 10:23 AM
twinturbo496's Avatar
I recommend you cut the wings off the case, I just pulled out my TH400 with wings, and had to remove one header, the 4L80E with the wings removed went in much easier, and next time it will come out without removing the header.
Old Jan 12, 2009 | 10:41 AM
forcd ind's Avatar
depending on what your going to do, there are some basic things i have found
larger front stator bushing, anti walk rear bushing, 5 clutches in direct drum, some pump work with new valving, some work on the valvebody, the transgo shift kit does that-a lot depends on the year case
Old Jan 13, 2009 | 10:42 PM
crf538's Avatar
i didnt see a yellow tag, only a blue rebuild tag that i didnt see a date on, but it came out of like a 94 truck so i assume it is the older model, i read that the newer ones were better but i got this one for $100 so i figured it was worth a shot
thanks for all the info, i mainly just want to bring up all this to my trans guy just to make sure
on another note, is anyone running the trinity trans brake with the automatic valve body, looks like a good deal i just wanted to talk to someone that was running one
thanks
