new to a glide...questions
Old Jan 13, 2009 | 07:10 AM
GTP PWR's Avatar
Default new to a glide...questions
I have put together a drag truck. I just picked up a Glide from a buddy.
now.... what converter, and what shifter?
I need around a 3400stall....
and I dont really want to hack up my center console for a new big shifter...
also... there are 2 levers on the side of my powerglide...
I imagine one is for high and low, and the other is for park, and reverse correct?
I have had 4L60's, TH400's.... this is my first glide. any info would be great!!!
Old Jan 13, 2009 | 08:58 PM
NovaCain383's Avatar
A Glide only has one lever on it. Not sure what you have if it has more than one.
Old Jan 13, 2009 | 10:05 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Post a picture of what you bought, that will help?
Old Jan 14, 2009 | 07:51 AM
Vortech Converters's Avatar
Restricted User
Default A stock glide has
2 levers. 1 is the shifter linkage the other is the kickdown linkage.
In a racing app the lever gets changed to a single solid shift shaft.
The converter needs to have a bushing for the turbine.
Converter builders >>> so many choices!!
Shifter >> the one that feels the most comfortable.
