speed inc flexplate and th400 help
Old Jan 13, 2009 | 09:19 PM
crazygn's Avatar
Default speed inc flexplate and th400 help
I bought a speed inc flexplate for my th400 trans and th400 3 bolt stall. What else is needed to bolt it up. If it still needs the spacers can someone give me a part number for the spacer so i can order the right stuff the first time.
thanks for your time
Old Jan 14, 2009 | 01:49 PM
9sec93's Avatar
you will need the crank adapter to center the converter on the crank. that and you will most likely have to open up the holes on the flexplate a bit. pics here..... https://ls1tech.com/forums/automatic...flexplate.html
Old Jan 14, 2009 | 05:14 PM
crazygn's Avatar
thanks does anyone have a part number, looks like they make one that bolts to the crank or flexplate and a small one that just sits in place thats around 40-50.00
Old Jan 14, 2009 | 05:31 PM
9sec93's Avatar
Hughes part number HP3795
