TH400 cable, which are you using...
right, you are using the stock shifter. im not.... the button on my shifter is for the transbrake... im looking for peoples input who have the same shifter or similar and want to know how they are routing things and what length cable they are using so that its not binding up.
Im running the B&M 5' heavy duty cable. I run it out the exact same hole as the factory one, down the passenger side of the Tranny case, loop it around(in front of the trans mount) and back towards the gear selector on the TH400. I run it the exact same way B&M recommends and it works great!!
