Shift Kit now what??
Old Jan 21, 2009 | 09:51 PM
2K1WS6400's Avatar
Default Shift Kit now what??
Yeah i have a 2k1 ws6 with 4l60e tranny and already have a tci3400 stall tourque converter...well im going to install a transgo shift kit with a transgo CORVETTE SERVO..well been thinking of installing why im ther some 3.73 gears or some other gear need some input in this..also what else should i replace wille im on it or something that might breake needed to be replaced..
car has 130k miles and mods are
slp lid with intake
magnaflow exhuaust
future: headers and y pipe and tune
maybe a cam???
Old Jan 22, 2009 | 12:21 PM
2K1WS6400's Avatar
daily bump
Old Jan 22, 2009 | 12:30 PM
performabuilt's Avatar
LS1Tech Sponsor
Well I would not bother with the corvette servo as your car already has one in it ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 22, 2009 | 12:50 PM
2K1WS6400's Avatar
lmao..wtf...i thought it didnt..well i went to the performance shop today and they said i was going to need this thing for the tranny that looks like housing with teeth because they said the shift kit was going to rip the teeth off and i need a stronger one...anybody know what that thing is and were i can get a reasonably priced one?? it looks lie a hollow fat circular housing with another smaller circular housing with teeth anfd goes in the tranny
Old Jan 22, 2009 | 01:01 PM
382ssz28's Avatar
Reverse Drum called the Beast. Call a sponsor, they stock them, and have other parts you may need. They also will only sell you what you need. Good luck.
Old Jan 22, 2009 | 01:48 PM
deadmanTA's Avatar
Think it's called a sun shell, the strongest one is called "the Beast". It would be a good upgrade if you had the tranny apart, but I don't see it as a must because of the shift kit and bolt-ons. Talk to one of your sponsors before buying parts.
Old Jan 22, 2009 | 01:59 PM
slayerized6's Avatar
get a new rear before the cam
Old Jan 22, 2009 | 02:28 PM
2K1WS6400's Avatar
thanks guys so what would be the parts i would need for a basic better than stick tranny cuz right now im understanding i would be enough with the ust the shift kit right or should i get that the beast part too and what else???
Old Jan 22, 2009 | 03:54 PM
deadmanTA's Avatar
You don't have to remove the tranny to install the shift kit but you would to intall that sun shell. I plan on just the shift kit and maybe the billet 2nd and 4th servos. I'll get the internal stuff if/when I blow up the tranny.
Old Jan 22, 2009 | 06:22 PM
2K1WS6400's Avatar
For the transgo kit u do have to take out the tranny...u think it would be worth it to replace the sunshell? planning on adding headers and y pipe and bigger tb wit bigger maf with a tune ...also the 3.73 gear or the 4.10 gears wile im at it which one?? i dont want to kill my mpg( ust some though) but want to get that nice acceleration??
Old Jan 22, 2009 | 06:32 PM
deadmanTA's Avatar
Sorry, I was under the impression that the shift kit could be done under the car. Do you have a stall? I'm going to try the 3.73's first, but I have a 4K stall and cam also.
Old Jan 22, 2009 | 06:44 PM
2K1WS6400's Avatar
yeah i have a tci3400 stall...y???
Old Jan 22, 2009 | 07:47 PM
2K1WS6400's Avatar
Well im thinking of gettin but tell me if im missing something:
please need input of the parts were to get them cheap and from who!!
Transgo Shift kitmany diffrent ones dont know were to get it)
servo(best brand please help):
overdireve servo(best brand Please Help):
Sunshell planning on the beast:
3.73 gears ( Brand help needed):
Old Jan 22, 2009 | 08:04 PM
deadmanTA's Avatar
PM some of the tranny sponsers. They have personal experiance w/ the differant manufacturers. You have one in this thread.
Old Jan 22, 2009 | 08:39 PM
LS1Tech Sponsor
1- the transgo hd2 can be installed partially without trans removal . Installing the 3-4 clutch return springs will require removal.
2- I would not use and servo beyond the corvette servo that's already in there with the stock band/ (I have seen the billet servos break the stock band)
3- the beast is a great idea ,
4-And upgraded 3-4 clutch set would be silley not to add while it apart.
Oh and not being a smart *** really if your going to do all of that and will be completely disassembling the transmission just finish the rebuild it would be crazy not to and unless your doing it all yourself (not suggested unless you are a trans builder or know someone with experience building performance 4l60e units) you are likely when all said and done gonna end up wIth as much money in the trans as you could buy one already built for or close.
If I wasnt gonna build the whole trans I would just do the partial install of the transgo and set it in the lighter shift settings and leave it at that, IMO
__________________
Call 888-744-6542
Old Jan 23, 2009 | 01:37 PM
2K1WS6400's Avatar
Will the upgraded servo work on a kevlar band not the wideband though ust the regular kevlar one will it hold up??
Old Jan 23, 2009 | 11:07 PM
thislswon's Avatar
dont forget a tranny cooler
Old Jan 23, 2009 | 11:43 PM
2K1WS6400's Avatar
kevlar band regular not the wide one will it work with upgraded servo..
Old Jan 24, 2009 | 02:54 AM
PBA's Avatar
PBA
The stock Borg Warner Hi-Energy band is much much better than the Kevlar band. Almost nobody that builds 700R4/4L60E units "that live", use the Kevlar band.
