Engine To Bellhousing Dowl Pins?
Old Jan 23, 2009 | 01:08 PM
Camaro396's Avatar
Default Engine To Bellhousing Dowl Pins?
Does anyone know off hand what size the dowl pins are that go into the back of the block to mate the engine to the transmission? Or where I can get them? I've called all the local dealers, with no luck, and would like to get this transmission in asap. Thanks.
-Lance
Old Jan 23, 2009 | 05:09 PM
9000th01ss's Avatar
Not knowing your situation I can tell you what I would do.
Look for any small block, big block, 4.3 V6, and I'm sure theres more. The pins are the same and usually clean up to like new.
I know of a 4.3 in the woods, I know the local junkyard would let me get some off a block either in the discard pile or the yard, probably for free.
Old Jan 23, 2009 | 08:43 PM
Firechikn's Avatar
How the hell did they come out. I've never seen them removed. haha Like stated, junkyard will save the day.
Old Jan 23, 2009 | 11:42 PM
Camaro396's Avatar
There is still one in the motor, the one just came out with the bellhousing when the T56 was pulled, and forgot to grab it before it got sold, so now the TH400 is going in, and we need to replace the one. From what I can tell, the dowels on my SBC motor are a lot bigger than the LS1 dowels.
Old Jan 24, 2009 | 11:18 AM
jay_lt4's Avatar
should be the same as any small block/ big block, even a 4.3 v6,,
think about it, all the gm transmissions interchange(even old th350/400's can be bolted right up to a lsx engine) and have the same size dowel hole, so just pull one from a used engine somewhere
Old Jan 24, 2009 | 06:07 PM
01ssreda4's Avatar
^^^^why cant you reach up and put a caliper on them and measure their diameter?
Old Jan 24, 2009 | 06:35 PM
9000th01ss's Avatar
.625 like every other 90 degree chevy on the planet.
Old Jan 24, 2009 | 06:56 PM
9000th01ss's Avatar
Ok here ya go.
Part# 1453658
https://ls1tech.com/forums/generatio...t-numbers.html
https://ls1tech.com/forums/manual-tr...er-needed.html
https://ls1tech.com/forums/lsx-parts...owels-etc.html
http://www.crateenginedepot.com/stor...53658-1059.htm
http://www.currymotors.gmmotors.com/...es.aspx?Page=1
http://paceperformance.com/index.asp...roductID=75443
http://www.turbobuick.com/forums/gen...ment-pins.html
http://www.jrgmparts.com/GM_Performa...gm_chevy_.html
That enough?
Old Jan 24, 2009 | 07:01 PM
9000th01ss's Avatar
http://www.pronto.com/1453658-G.M.-B...p_509263905-PP
Old Jan 24, 2009 | 10:47 PM
Camaro396's Avatar
Thanks, we got them today
