Overheated 4L60E
Old Jan 25, 2009 | 10:00 PM
LS1_K1DD's Avatar
Default Overheated 4L60E
Hey guys, well heres the breakdown. 3800 SBS, no trans cooler. Drove the car for about 2 1/2 hours straight last night and was hot rodding it a little bit. Well when i was cruising into a bank parking lot to the ATM the car started acting funny. Had to give it about 3k rpms to move and then when it got moving it shifted fine. So i drive 40 FT. down the road park it and turn her off.
Popped the hood, some ATF looked like it came out of the tube. Checked the level of ATF, which was fine and right where it was supposed to be at even though some came out. Smelt a little burnt, just got a hint of it. Leave the car parked for 2 hours if not more, came back started it up and it drove fine. Moving at about 1100 RPMS like it usually does with my stall.
Get a mile down the road, park it for another hour. Then i head home later that night(45 miles away). Car drove fine all the way home. Went out this morning and there was no ATF under the car, on the pan, anywhere. Drove fine to my ex gf's house. Well drove it home tonight, everything shifted/sounded fine and was perfect. Put a little ATF in it tonight and test drove her again and it seems just like normal. Is it safe to assume everything is ok? The ATF is still red and smells fine. Is she ok? Moves and drives perfect. Am i lucky? Let me know your opinions on this.
Thanks - Zack
LS1_K1DD's Avatar
PS, sorry for the long post, im just stressin over this even though the car seems fine. Its nerve wrecking. Also a trans cooler will DEFINATLY be ordered friday and the car will only be driven 14-15 miles a day to work and back.
Old Jan 25, 2009 | 10:28 PM
performabuilt's Avatar
LS1Tech Sponsor
A cooler is certainly in order, Also make sure you do have lockup and scan for codes
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 25, 2009 | 10:41 PM
LS1_K1DD's Avatar
So you think its ok then? Cooler will be ordered friday. Its thrown the SES off and on since the stall went in.
Old Jan 25, 2009 | 10:58 PM
LS1Tech Sponsor
You still need to check codes sounds like you went to limp mode, Get it scanned then report back with the numbers .
Trans sounds like ok for now
__________________
Call 888-744-6542
Old Jan 25, 2009 | 11:00 PM
LS1_K1DD's Avatar
Whats limp mode? The heat cause this temporarily?
Old Jan 25, 2009 | 11:04 PM
LS1Tech Sponsor
It could but on the other hand the code could be causing the heat too get it scanned
__________________
Call 888-744-6542
Old Jan 25, 2009 | 11:08 PM
LS1_K1DD's Avatar
OK will do. This is the first time its done this and the stall has been in a month and a half. It won't hurt to drive the car will it? maybe 15 minutes max, at a time.
Old Jan 25, 2009 | 11:09 PM
LS1Tech Sponsor
It should be ok
__________________
Call 888-744-6542
Old Jan 25, 2009 | 11:13 PM
LS1_K1DD's Avatar
K. Thanks, ill scan her tomarow at work and report back.
Old Jan 25, 2009 | 11:19 PM
LS1Tech Sponsor
Cool will be watching as always
__________________
Call 888-744-6542
Old Jan 26, 2009 | 12:12 AM
AutomagicLS1's Avatar
limp mode can be a scary feeling when leaving in traffic at a stoplight if ya have never experienced it
Old Jan 26, 2009 | 08:11 AM
mike13's Avatar
After scanning for codes if everything is ok I would flush the trans fluid when you install you cooler. Once you overheat trans fluid you really shorten it's ability to protect your trans.
Old Jan 26, 2009 | 08:50 PM
LS1_K1DD's Avatar
Well a couple codes popped up. New 02 sensor, trans cooler, and slight tune will fix it!
