What causes a transmission to slip?...
Old Jan 27, 2009 | 09:07 AM
Stroker2112's Avatar
Default What causes a transmission to slip?...
I have a re-occurring issue with my 4L60E where it "slips" during WOT. Basically, it disengages at approx 4000 rpms (in 2nd gear) and the rpms spike up briefly to 5000+, and then returns back before shifting into 3rd. What is the cause of this?....I have a vac mod controlling the line pressure...
Old Jan 27, 2009 | 09:56 AM
tptransmission's Avatar
Closed ex-Sponsor Account
Verify you are using manifold vacuum not ported vacuum.
Old Jan 27, 2009 | 10:27 AM
I'm tee'd in off the master brake cylinder hose ...is there a better hose to tap in to?...
Old Jan 27, 2009 | 10:44 AM
The vacuum modulator is designed to give you max pressure when you have low vacuum such as manifold vacuum under heavy throttle. The brake cylinder or booster will act as a reservior and hold the vacuum high causing low pressure during shifts. Finding a different vacuum source will depend on your intake your are running.
Old Jan 27, 2009 | 11:42 AM
performabuilt's Avatar
LS1Tech Sponsor
It is also possible its not a slip at all , Since the band is released during the 2-3 shift it could be a matter of hydraulic timing. There could be too much fluid going to release the servo to fast and basically if this happens and the band is released to soon before the 3-4 clutch can apply you will in fact go momentarily back to first, Which would feel like neutral or a slip followed by third.
Did you install the shift kit your self its possible that a wrong hole could have been enlarged in the spacer plate and what servo are you using ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 31, 2009 | 09:30 PM
sounds like I need to change my vac mod tap. Performabuilt your description of what's happening is spot-on.... I'm not sure what servo is in it (it's an aftermarket trans)...is the shift kit something I could easily check out and/or replace myself?...
Old Jan 31, 2009 | 10:30 PM
LS1Tech Sponsor
Well for that issue I would consider changing the transfer plate, However you really need to know whats in it to fix it shift kit wise,
__________________
Call 888-744-6542
Old Feb 1, 2009 | 07:16 PM
mike13's Avatar
How does it work for a boosted car?
Old Feb 2, 2009 | 08:15 AM
big wally 55's Avatar
The brake booster has a check valve . It will not trap vacuum in the line , it will keepit in the booster ! Trans-go makes a valve for turbo/ boosted setups . The problem you describe sounds like a shift timing/tune issue .
