Which trans mount should I go with
In an A4, usless your really hard core, go with a 1LE GM replacement mount. The aftermarket poly bushings transfer alot of vibration into the interior of the car.
lata
Bill
I got my last one from SDPC our sponsor. Call them up. They'll hook you up!
It appears to be a softer durometer rubber and is considerably taller than the stock OEM piece. So much in fact I had to take the top half of my driveshaft loop off to make it work. It pushed the tranny higher into the tunnel to the point it looks odd. I also think it screwed up my pinion angle big time, but I'm not entirely sure.
