Need help completing the 'list'. M6 to A4
Old Oct 19, 2003 | 09:52 AM
TA2SLOW346's Avatar
Default Re: Those that have performed a M6 > A4 conversion inside please
I was told that I needed to use a Lokar 36" dipstick kit...is there only 1 specific 36"? Do any of the sponsors carry them or would I be better off buying direct? About the tranny mount...what brand, material, etc. should I go with? Thanks for your help!
Why wouldnt stock F-body A4 trans dipstick work?
You cant use the stock A4 trans dipstick because on a 200r4 the dipstick hole is located further back on the transmission then it is a 4l60e.
The lokar dipsticks work great, they have trans mount and engine mount ones, I used the trans mount.
Your also going to have to fab up a TV cable bracket unless you go with a manual valvebody.
I did the A4 to 200r4 swap and havnt looked back since. I did everything myself inculding building the 200r4.
Old Oct 20, 2003 | 08:49 PM
Dragaholic's Avatar
9 Second Club NA
Default Re: Need help completing the
Are there any other little parts that Im leaving out that I wouldnt think of? Ex: brackets, levers, cables, etc.? Thanks
Old Oct 21, 2003 | 04:40 PM
Dragaholic's Avatar
9 Second Club NA
How crucial is it to use the park lock cable? Anyone have a how to or could explain how to install it and the wiring? Thanks
Old Oct 23, 2003 | 09:24 PM
Dragaholic's Avatar
9 Second Club NA
Well...Ive got the dipstick kit, the tranny mount, the tranny cooler, the tranny temp. gauge, and automatic pedal assembly all knocked out. Hopefully by tomorrow I will have the top portion of the console. Im still needing the shifter, leather wrapped Firebird T-shaped ****, range selector cable/bracket/lever, park lock cable/lever/bracket, converter, and driveshaft. If you have any of these parts for sale besides the converter and driveshaft, please let me know. Thanks!
