Stall question. What will I stall at right now?
Old 02-03-2009, 04:43 PM
matthewjosh's Avatar
Default Stall question. What will I stall at right now?
OK I ordered a 4400 stall I told them I wanted a 2.1 str. I told them I was making 470 rwhp and weighed 3100lbs. This is my goal pwr and weight, I wanted something to work into. The question is with my current setup which is around 400rwhp and 3300 to 3400lbs what will it stall at now due to less pwr and more weight than it was built for.. any ideas?>
Old 02-03-2009, 06:36 PM
LS1Tech Sponsor
performabuilt's Avatar
Should stall a little less than expected but not way off
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-04-2009, 10:23 AM
I thought it would have been the opposite. since you stall lower if you drop weight.... so if more power you stall higher?
