4l60e LT1 Trans behind LS1 will it work
Old Feb 4, 2009 | 06:45 PM
rusty2198's Avatar
Default 4l60e LT1 Trans behind LS1 will it work
Ok I searched can't find the answer but will a lt1 trans work behind a Ls motor? I can get a 5.3 complete and was wondering if I can bolt this to my trans in my car. I have a rebuilt 4l60e with a vigilante 3500 stall. I was wanting to take this 5.3 bore it out and install factory ls1 pistons in it I checked part # on the crank and it is the same # as the 5.7l I read in other post that bored .030 makes a 5.3 a5.7
Old Feb 4, 2009 | 07:50 PM
performabuilt's Avatar
LS1Tech Sponsor
Cant answer the bore question but I can answer the trans, Yes it will you will need a converter pilot spacer but other than that you should be good to go
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 5, 2009 | 08:23 AM
camaroz28lt1at's Avatar
So a LT1 stall and tranny will work behind a LS motor with just a spacer? What if you have a LS bellhousing? What about the electronics, plug and play?
Old Feb 5, 2009 | 06:23 PM
rusty2198's Avatar
yea what camaroz28lt1at asked. I assumed that the electronics are the same but not real sure also If I get the ***** to do this swap I will be running a 99 wiring harness.
Old Feb 5, 2009 | 06:31 PM
LS1Tech Sponsor
96 up electronics are the same. You cannot use and LSx bell on a lt-1 trans.
__________________
Call 888-744-6542
Old Feb 5, 2009 | 06:38 PM
9000th01ss's Avatar
So the OP wants to bolt a 5.3 to an LT1 4L60E?
Should bolt right up.
No ones bolting an LT1 trans to an LS1 in this thread.
Old Feb 5, 2009 | 07:21 PM
bww3588's Avatar
yes they are...
Old Feb 5, 2009 | 07:46 PM
LS1Tech Sponsor
A 5.3 may not be and ls1 but is lsx based
__________________
Call 888-744-6542
Old Feb 5, 2009 | 10:04 PM
9000th01ss's Avatar
I guess I was thinking of the early LS based 6.0 that used a 4L80E and converter that could bolt right to a Gen1, or in my case a Mark IV big block.
Old Feb 5, 2009 | 10:35 PM
tptransmission's Avatar
Closed ex-Sponsor Account
That almost sounds like an apology, I am sure glad I have never misread a thread. This crowd is brutal.
Old Feb 5, 2009 | 10:39 PM
LS1Tech Sponsor
Oh trust me They can be lol
__________________
Call 888-744-6542
Old Feb 5, 2009 | 10:46 PM
Part of the business and good for entertainment if anything else.
Old Feb 5, 2009 | 10:49 PM
95formulalt1's Avatar
it will not work!! i have a lt1 tranny and ls1 motor in my 95 ta. my car drives like ****! im looking for a ls1 tranny now. u can drive it but there is no power. shifts at 2k and wont down shift at WOT.
Old Feb 5, 2009 | 10:55 PM
That is not related to the lt1/ Ls1 transmission they are not that much different. There is another problem such as throttle position, vehicle speed, power to the transmission ETC....
Old Feb 5, 2009 | 10:56 PM
9000th01ss's Avatar
Originally Posted by bww3588
yes they are...
So my work truck has a 5.3 liter LS1?
I guess I can rev at people and just tell them it's got an LS1, cool. The vette engine.
Old Feb 5, 2009 | 11:05 PM
rusty2198's Avatar
Default this may help
My trans did the same thing when my TPS shorted may not be your prob but worth looking into. Sucks ***** hitting second at 2k. Also my lock up didn't work.
Hey BTW nice T/A
Old Feb 5, 2009 | 11:06 PM
And most would believe you. A small block is still a small block no matter how you package it. Corvette engine just sounds impressive to some.
Old Feb 6, 2009 | 01:01 AM
bww3588's Avatar
please tell me your joking.....
the LS1 and LM5/LM7 have the same block, just different bore, and material. if it will work on the LS1, it will work on the 5.3. simple as that.
Old Feb 6, 2009 | 06:37 AM
9000th01ss's Avatar
Well since you can't detect the obvious, yes I am.
Lighten up tough guy it's the internet, we don't want to lose more money by being a smartass to someone now do we?
Old Feb 6, 2009 | 05:31 PM
98childsta's Avatar
He did say please in the very beginning.
