shifts to 4 early
Old Feb 6, 2009 | 02:12 PM
72chevelle6.0's Avatar
Default shifts to 4 early
I have a built trans with a 3000 stall I got everything in and was driving it. Everything was fine then the trans when to shifting in to 4th early so I pulled the DTC and got a P0748 code for the shift solenoid. I also found that the vacuum line had come off not sure how long it has been off. could the vacuum line coming off have caused some damage? I cleared the DTC and it is still shifting early. or am I looking at a wiring issue?
Old Feb 6, 2009 | 03:02 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Are you using vacuum to control line pressure?
Old Feb 6, 2009 | 03:04 PM
I guess so I don't think the trans had the vaccum mod done..
Old Feb 6, 2009 | 03:06 PM
You mentioned a vacuum line comming off. What is that for. 748 is a pressure control soleniod code and would just cause firm shifts. Early shifting is a sign of a bad tps signal or Vehicle speed to the controller.
Old Feb 6, 2009 | 03:08 PM
oh sorry it is the vaccum line that runs to the 4L65E tans in my car.
Old Feb 6, 2009 | 03:14 PM
could the trans desired TQ in the TM screen of the tune being set to 640 cause this?
Old Feb 6, 2009 | 03:51 PM
performabuilt's Avatar
LS1Tech Sponsor
And early shift could be a TPS or MAF calibration error
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 6, 2009 | 04:12 PM
hmm ok I will check them out
