Truck 4L60E in Fbody?
Old Feb 8, 2009 | 07:48 PM
Shift2007's Avatar
Default Truck 4L60E in Fbody?
Hey guys, I have a 1991 Trans Am, and I am swapping in an LS1 and 4L60E. I can get a good deal on a 4L60E from a truck, but I was wondering if they are the same as the 4L60E's from an fbody? Anything I should look out for? Are there different input shafts with a different number of splines?
Old Feb 8, 2009 | 08:49 PM
ryan00z28camaro's Avatar
i have a 4l60e im pulling out of my car i could let go for cheap will also be refreshed before lmk shoot me a pm if interested
Old Feb 8, 2009 | 08:52 PM
performabuilt's Avatar
LS1Tech Sponsor
You will need to use a 4L60E from and LSX engine based vehicle wether it be a truck or and f body
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 8, 2009 | 10:27 PM
ZR2_350's Avatar
PM sent Ryan.....
Old Feb 8, 2009 | 10:28 PM
deadhorse66's Avatar
Actually, any of the later 4L60-E transmissions will work. What you are looking for is a bellhousing that unbolts from the main case, and the large input shaft that is splined all the way to the end. These came in everything from S-10s to express vans from 98 to 06 if I'm not mistaken. Basically, you find anything that is a V8/4L60 combo in those year breaks and you'll have a direct bolt in provided that its a 2 wheel drive.
Old Feb 8, 2009 | 10:56 PM
LS1Tech Sponsor
Incorrect the 4.3 s-10 does have a bolt on bell but not the LSX shaft and stator that you will only find in 5.3 6.0 trucks and in 5.7 f bodies along with 04-06 gto 5.7 and 6.0
Some 98 5.7 trucks were not lsx based so will not have this.
Bolt on bells popped up around late 96 but were LT-1 shaft and stator along with a shalow bell housing.
Some wanna call the LSX based 4l6oe a 65e but it is not .
__________________
Call 888-744-6542
Old Feb 8, 2009 | 11:48 PM
antsls1's Avatar
shift2007 listen to performabuilt he knows what he is talkin bout i basically have the same prob but is solved now thanks to him
Old Feb 9, 2009 | 09:28 AM
Shift2007's Avatar
Thanks guys!
Old Feb 9, 2009 | 12:21 PM
Originally Posted by deadhorse66
...and the large input shaft that is splined all the way to the end.
My mistake. I could have sworn I've seen this on Colorados. What I meant to say was S/T trucks instead of S-10. Is the stator different for the later 4L60? Guess I shouldn't have been so quick to run my mouth.
Old Feb 9, 2009 | 12:31 PM
LS1Tech Sponsor
Yes all the LSX based engines use a 4l60e with a different stator and input shaft. While the 4.3 retains the earlier style shaft and stator lt-1 style
__________________
Call 888-744-6542
